Use themler and my programmer to work on a website
andreasportpeoples
andreasportpeoples posted this 16 May 2018
Hi I'm creating a website and I would like to know if my programmer and I can use themler with the same subscription to work on this website I'm creating.
In italian
Salve sto creando un sito web e vorrei sapere se io e il mio programmatore possiamo usare themler con lo stesso abbonamento per lavorare su questo sito web che sto creando.
Hi I'm creating a website and I would like to know if my programmer and I can use themler with the same subscription to work on this website I'm creating. In italian Salve sto creando un sito web e vorrei sapere se io e il mio programmatore possiamo usare themler con lo stesso abbonamento per lavorare su questo sito web che sto creando.
Support Team posted this 16 May 2018
Subscription is applied to your account. You can share the login details with your partner (if you totally confident) and then you can use the application with the same login details. But note, that only one person can be logged in at a time. So once your partner starts to work, you should log out.
Hi, Subscription is applied to your account. You can share the login details with your partner (if you totally confident) and then you can use the application with the same login details. But note, that only one person can be logged in at a time. So once your partner starts to work, you should log out. Sincerely, Hella
