Cookies used by Themler
namit
namit posted this 17 May 2018
Reg. to new EU GPDR (and old) there is required to inform users about cookies used in site.
Could you explain purpose of use cookies by themler in frontend (componentType and others) ?
Reg. to new EU GPDR (and old) there is required to inform users about cookies used in site. Could you explain purpose of use cookies by themler in frontend (componentType and others) ?
TBit Systems
TBit Systems posted this 18 May 2018
I am interested too.
Support Team posted this 21 May 2018
Themler creates themes only. To inform users about cookies you need to use corresponding CMS addons.
Themler Team
Hi, Themler creates themes only. To inform users about cookies you need to use corresponding CMS addons. Thank you, Themler Team
TBit Systems
TBit Systems posted this 22 May 2018
since some of the latest themler updates there are 2 new cookies in older versions there were only Joomla session cookies but those 2 componentStyle and componentType are new and if I change Template back to default Joomla template they are gone which means that themler generates its own cookies.
Hello, since some of the latest themler updates there are 2 new cookies in older versions there were only Joomla session cookies but those 2 componentStyle and componentType are new and if I change Template back to default Joomla template they are gone which means that themler generates its own cookies. Thanks
Support Team posted this 23 May 2018
In short, these two cookies used to apply corresponding template to the page. The componentType cookie records the type of the component (single page, blog, products, etc) and the componentStyle used to set the template.
Hi, In short, these two cookies used to apply corresponding template to the page. The componentType cookie records the type of the component (single page, blog, products, etc) and the componentStyle used to set the template. Thank you, Olivia
