Add custom html, can't be deleted
Alexander Dzhuninski
Alexander Dzhuninski posted this 21 May 2018
After adding custom HTML code in Prestashop 1.7 and saving, after that can't be deleted added custom HTML bloc/container. When i can find it, in which file in theme and delete, manually ?
Support Team posted this 21 May 2018
You cannot remove that control from the editor screen? Have you tried to remove it from the Outline tab in the left panel? Please provide an access to your site back end so we could try to remove it.
Hi, You cannot remove that control from the editor screen? Have you tried to remove it from the Outline tab in the left panel? Please provide an access to your site back end so we could try to remove it. Sincerely, Hella
No, access no, we restore backup
The location of code in the theme files depends on where you inserted the control and what control you used (HTML or CMS Code).
Hi, The location of code in the theme files depends on where you inserted the control and what control you used (HTML or CMS Code). Thank you, Olivia
