Displaying the image relative to the button
bcouvin
bcouvin posted this 23 May 2018
We would like to add a section with 2 containers displayed in 2 rows.
The first container contains 3 columns. Each column has text and one button.
The second container contains one image.
How could we assign the corresponding image to the button? We mean, when an user clicks on the button from one of the 3 columns, the image in the second container changes.
Do you have an idea how to do it properly?
Bertrand
Hello, We would like to add a section with 2 containers displayed in 2 rows. The first container contains 3 columns. Each column has text and one button. The second container contains one image. How could we assign the corresponding image to the button? We mean, when an user clicks on the button from one of the 3 columns, the image in the second container changes. Do you have an idea how to do it properly? Thanks Regards Bertrand
Support Team posted this 23 May 2018
Unfortunately Themler itself does not provide such functionality. It requires creation of custom HTML and js code. As alternative you can search for the CMS component which creates the desired elements.
Hi, Unfortunately Themler itself does not provide such functionality. It requires creation of custom HTML and js code. As alternative you can search for the CMS component which creates the desired elements. Thank you, Olivia
