Themler v.456 export from Prestashop
provaznik
provaznik posted this 01 June 2018
we have a new version of Themler and we need to export our theme from desktop. But there is same error:
OS: Windows NT DELL-T3500-GS2 6.2 build 9200 (Windows 8 Business Edition) i586 E_WARNING: json_decode() expects parameter 1 to be string, array given C:\ProgramData\Themler\hd_data\themler_1586124520\prestashop\modules\designer\DesignerTabSelf.php 62 Array ( [info] => Array ( [id] => fnj7stondqo [content] => [current] => 2 [total] => 2 [encode] => 1 [blob] => 1 ) [chunk] => Chunk Object ( [UPLOAD_PATH] => C:/ProgramData/Themler/hd_data/themler_1586124520/prestashop/upload/chunks/ [_lastChunk:Chunk:private] => Array ( [id] => fnj7stondqo [content] => [current] => 2 [total] => 2 [encode] => 1 [blob] => 1 ) [_chunkFolder:Chunk:private] => C:/ProgramData/Themler/hd_data/themler_1586124520/prestashop/upload/chunks/fnj7stondqo [_lockFile:Chunk:private] => C:/ProgramData/Themler/hd_data/themler_1586124520/prestashop/upload/chunks/fnj7stondqo/lock [_isLast:Chunk:private] => 1 ) ) Callstack: -> json_decode(array(2) { ... }, true) -> DesignerTabSelf::save(array(6) { ... }) -> AdminAjaxController::ajaxProcessSave() -> AdminControllerCore::postProcess() -> AdminAjaxController::postProcess() -> ControllerCore::run() -> DispatcherCore::dispatch()
See you image.
Thank you? Drahomira
Hi, we have a new version of Themler and we need to export our theme from desktop. But there is same error: OS: Windows NT DELL-T3500-GS2 6.2 build 9200 (Windows 8 Business Edition) i586 E_WARNING: json_decode() expects parameter 1 to be string, array given C:\ProgramData\Themler\hd_data\themler_1586124520\prestashop\modules\designer\DesignerTabSelf.php 62 Array ( [info] => Array ( [id] => fnj7stondqo [content] => [current] => 2 [total] => 2 [encode] => 1 [blob] => 1 ) [chunk] => Chunk Object ( [UPLOAD_PATH] => C:/ProgramData/Themler/hd_data/themler_1586124520/prestashop/upload/chunks/ [_lastChunk:Chunk:private] => Array ( [id] => fnj7stondqo [content] => [current] => 2 [total] => 2 [encode] => 1 [blob] => 1 ) [_chunkFolder:Chunk:private] => C:/ProgramData/Themler/hd_data/themler_1586124520/prestashop/upload/chunks/fnj7stondqo [_lockFile:Chunk:private] => C:/ProgramData/Themler/hd_data/themler_1586124520/prestashop/upload/chunks/fnj7stondqo/lock [_isLast:Chunk:private] => 1 ) ) Callstack: -> json_decode(array(2) { ... }, true) -> DesignerTabSelf::save(array(6) { ... }) -> AdminAjaxController::ajaxProcessSave() -> AdminControllerCore::postProcess() -> AdminAjaxController::postProcess() -> ControllerCore::run() -> DispatcherCore::dispatch() See you image. Thank you? Drahomira
Support Team posted this 01 June 2018
Please try to temporarily disable antivirus and firewall, as well as third-party add-ons for the Chrome browser. Does the issue continue after this?
Hello, Please try to temporarily disable antivirus and firewall, as well as third-party add-ons for the Chrome browser. Does the issue continue after this? Sincerely, Nettie, BillionDigital Team
provaznik
Hello Nettie,
I tried ti disable antivirus and firewall. But export doesn't still work. There is the same mystake.
Drahomíra
Hello Nettie, I tried ti disable antivirus and firewall. But export doesn't still work. There is the same mystake. Drahomíra
Support Team posted this 04 June 2018
Hello Drahomira,
Please try to run this URL in Chrome or Firefox browser directly: http://127.0.0.1:12080/themler_1586124520/startup
Can you export if you open the theme in this way?
Hello Drahomira, Please try to run this URL in Chrome or Firefox browser directly: http://127.0.0.1:12080/themler_1586124520/startup Can you export if you open the theme in this way? Sincerely, Nettie, BillionDigital Team
