wordpress home button takes me off site to random url
lavisbre
lavisbre posted this 02 June 2018
http://sweetwatermasonry.com home button takes me too http://wordpress.4.i70509.cms1-live.billiondigital.com/
I have a page set up as home
I have wordpress set to home page
i have it set as static file "home"
yet the home button takes me too http://wordpress.4.i70509.cms1-live.billiondigital.com/
Please advise
Alan
Hello http://sweetwatermasonry.com home button takes me too http://wordpress.4.i70509.cms1-live.billiondigital.com/ I have a page set up as home I have wordpress set to home page i have it set as static file "home" yet the home button takes me too http://wordpress.4.i70509.cms1-live.billiondigital.com/ Please advise Alan
wpexpertinbd
wpexpertinbd posted this 02 June 2018
Hello, from wp-admin go to setting---->general--- check your site url & home url, you need to set them to: http://sweetwatermasonry.com , hope it will help you!
Support Team posted this 02 June 2018
Hello Alan,
Benjamin's instruction should work. If it doesn't, please, let us know.
Gina,
Hello Alan, Benjamin's instruction should work. If it doesn't, please, let us know. Gina, Themler Support
wpexpertinbd
Hello, I found same issue with one of my client site today & I found the solutions.
Solutions:
1. First setup your site url & home url to your domain name
2. If 1st option not working for you then remove "Home" from main menu & then insert it again & hit save button. It should be working fine.
3. Why it's happen, I found this issue with latest version of themler & this happen if you load demo data while you installing themler theme.
Hello, I found same issue with one of my client site today & I found the solutions. Solutions: 1. First setup your site url & home url to your domain name 2. If 1st option not working for you then remove "Home" from main menu & then insert it again & hit save button. It should be working fine. 3. Why it's happen, I found this issue with latest version of themler & this happen if you load demo data while you installing themler theme.
lavisbre
No iv done all of the above the first time. it is under the url, i did have a red menu alert and noticed the home page and so forth installed multiple times over 3 pages worth. like home blog and about was in 8 times.
I did load demo site twenty before installing themlar site
should i frag the whole install and reinstall WP and start new? or do you have a better solution as i dont want to disrupt the email service linked to this in ipage
No iv done all of the above the first time. it is under the url, i did have a red menu alert and noticed the home page and so forth installed multiple times over 3 pages worth. like home blog and about was in 8 times. I did load demo site twenty before installing themlar site should i frag the whole install and reinstall WP and start new? or do you have a better solution as i dont want to disrupt the email service linked to this in ipage
wpexpertinbd
You no need to reinstall WordPress again. Delete all unwanted page from "All pages", only keep that page which currently you use. Then go to menu & delete all menu. After create menu again freshly. Hope this will help you.
lavisbre
ah worked it out
I followed your guidance and it was done as suggested by your list, thank you for the directions.
Wp has menu settings under the menu list
Display location Primary Navigation 1was not ticked
now it does what it should, maybe add that to your list for anyone in my boat.
Thank you team themlar for being there
ah worked it out I followed your guidance and it was done as suggested by your list, thank you for the directions. Wp has menu settings under the menu list Display location Primary Navigation 1was not ticked now it does what it should, maybe add that to your list for anyone in my boat. Thank you team themlar for being there
wpexpertinbd
wpexpertinbd posted this 03 June 2018
Nice to hear that you figure out it!
