how to insert shot description
happy.ejassistant
happy.ejassistant posted this 3 weeks ago
http://prntscr.com/jpv62r
how to insert/included virtuemart short description in the product detail page?
http://prntscr.com/jpv62r how to insert/included virtuemart short description in the product detail page?
Please, check the instructions here http://answers.themler.io/articles/67028/tips-and-tricks#t_4
Hello, Please, check the instructions here http://answers.themler.io/articles/67028/tips-and-tricks#t_4 Sincerely, Gina Themler Support
happy.ejassistant
http://prntscr.com/jpwqqo
i cant find the cms code button?^ ^
http://prntscr.com/jpwqqo i cant find the cms code button?^ ^
happy.ejassistant
http://prntscr.com/jpxomu
how to adjust & make it display like the way i 1st key in at short description?
pls help tq
http://prntscr.com/jpxomu how to adjust & make it display like the way i 1st key in at short description? pls help tq
happy.ejassistant
hello ?
hello ?
  1. Open Product Details template.
  2. Navigate Insert >> Controls >> More >> CMS Code and insert this control to the desired location on the page.
  3. Click CMS Code tab >> Edit CMS Code and add the code below in php code format:
    <?php echo $this->product->product_s_desc ?>
Hello, 1. Open Product Details template. 2. Navigate Insert >> Controls >> More >> CMS Code and insert this control to the desired location on the page. 3. Click CMS Code tab >> Edit CMS Code and add the code below in php code format: `<?php echo $this->product->product_s_desc ?>` Sincerely, Nettie, BillionDigital Team
happy.ejassistant
i already insert the desc cms code
http://prntscr.com/jrjx17
pls check the screenshot , to understand what i want ^^ TQ
i already insert the desc cms code http://prntscr.com/jrjx17 pls check the screenshot , to understand what i want ^^ TQ
Themler simply displays the short description outputted by joomla. if you add <br> tag (which creates the line break) into the product short description joomla will cut this tag. Unfortunately this is not related to Themler and you will encounter this issue with the default joomla theme too. Most probably it can be solved with some third-party plugin but I not aware of such plugins unfortunately.
Hi, Themler simply displays the short description outputted by joomla. if you add `<br>` tag (which creates the line break) into the product short description joomla will cut this tag. Unfortunately this is not related to Themler and you will encounter this issue with the default joomla theme too. Most probably it can be solved with some third-party plugin but I not aware of such plugins unfortunately. Thank you, Olivia
