Themler for Prestashop
provaznik
provaznik posted this 04 June 2018
we use your software Themler for desktop. And for our e-shop we chose Prestashop, which you support. But we have big problems with Prestashop. First we tried Prestashop 1.7. We created a new theme, but it was impossible to import this theme for our e-shop. Your Prestashop 1.7 is supported very little. So we changed version and now we use Prestashop 1.6. But there are also problems here. Our customer demands for his e-shop fancybox instead of JqZoom. There is only one theme for desktop. This theme called Julia’s Store. When we try to import this theme into Prestashop there is same error. But we see this theme among other themes. We can open this theme, but design Themler desktop is different of design other themes (see pictures). We cannot update this theme and we cannot export this theme (Julia’s Store). There is not any other theme, which have Fancybox effect. We are not able set up Fancy box for our e-shop.
Can you tell how we can set up Fancybox? Can we overwrite same sourecode our theme?
We are very disappointed, that Prestashop does not work well and have only little support.
Drahomira
Hello, we use your software Themler for desktop. And for our e-shop we chose Prestashop, which you support. But we have big problems with Prestashop. First we tried Prestashop 1.7. We created a new theme, but it was impossible to import this theme for our e-shop. Your Prestashop 1.7 is supported very little. So we changed version and now we use Prestashop 1.6. But there are also problems here. Our customer demands for his e-shop fancybox instead of JqZoom. There is only one theme for desktop. This theme called Julia’s Store. When we try to import this theme into Prestashop there is same error. But we see this theme among other themes. We can open this theme, but design Themler desktop is different of design other themes (see pictures). We cannot update this theme and we cannot export this theme (Julia’s Store). There is not any other theme, which have Fancybox effect. We are not able set up Fancy box for our e-shop. Can you tell how we can set up Fancybox? Can we overwrite same sourecode our theme? We are very disappointed, that Prestashop does not work well and have only little support. Drahomira
Support Team posted this 04 June 2018
PrestaShop 1.6 themes are not compatible with PrestaShop 1.7. That's why you failed to install it.
We created a new export for PrestaShop 1.7:
http://answers.themler.io/questions/152227/themler-themes-for-prestashop-1-7-are-now-available-beta
Currently it is on Beta stage.
Unfortunately Themler product Image control does not support Fancybox. Only CloudZoom effect is available.
The JuliaStore theme does not support product image lightbox too. It is quite old. Therefore you need to update the theme to get the latest Themler version. But in both cases only CloudZoom effect is available for Product Image control.
Hello, PrestaShop 1.6 themes are not compatible with PrestaShop 1.7. That's why you failed to install it. We created a new export for PrestaShop 1.7: http://answers.themler.io/questions/152227/themler-themes-for-prestashop-1-7-are-now-available-beta Currently it is on Beta stage. Unfortunately Themler product Image control does not support Fancybox. Only CloudZoom effect is available. The JuliaStore theme does not support product image lightbox too. It is quite old. Therefore you need to update the theme to get the latest Themler version. But in both cases only CloudZoom effect is available for Product Image control. Thank you, Olivia
