Multi color header and text in Themler
Web IT Solutions LLP
Web IT Solutions LLP posted this 05 June 2018
Dear Sir,
I need one feature what other tools are offering in their desig. Like for <h1> tab hello world both letters I want too different colors.
Can you make this as default feature of headed ex. H1, h2, h3, h4 etc and text fields in Themler.
Any third party CSS Integration script please refer the link or sample code. And, you can make this as part of feature in next relese.
Open this ticket for others to vote for this feature too.
Thanks in advance,
Suffian Ahmed
Dear Sir, I need one feature what other tools are offering in their desig. Like for &lt;h1&gt; tab hello world both letters I want too different colors. Can you make this as default feature of headed ex. H1, h2, h3, h4 etc and text fields in Themler. Any third party CSS Integration script please refer the link or sample code. And, you can make this as part of feature in next relese. Open this ticket for others to vote for this feature too. Thanks in advance, Regards Suffian Ahmed
14 Comments
Support Team posted this 05 June 2018
We do not plan such feature. You can try to use the HTML control with the code that will include two <span> tags with the inline color values. Like this:
<h1><span style="color:red;">Hello</span><span style="color:blue;">world!</span></h1>
Hi, We do not plan such feature. You can try to use the HTML control with the code that will include two `<span>` tags with the inline color values. Like this: <h1><span style="color:red;">Hello</span><span style="color:blue;">world!</span></h1> Sincerely, Hella
Hi Hella,
Can we do it same for Horizontal Menus...
Each menu with different colors and icons if we need it ?
Suffian Ahmed
Hi Hella, Can we do it same for Horizontal Menus... Each menu with different colors and icons if we need it ? Regards Suffian Ahmed
The menu item name cannot be edited as the HTML so that is not possible. The color of the item background can be added as the custom CSS code. But we do not support such custom modifications.
Hi, The menu item name cannot be edited as the HTML so that is not possible. The color of the item background can be added as the custom CSS code. But we do not support such custom modifications. Sincerely, Hella
Ok, at least Is there any way to use some third-party CSS to achieve the same with different colors menus...
Share some third party links so that we can explore the same.
Thank in advance, Appreciate your quick response...
Suffian Ahmed
Ok, at least Is there any way to use some third-party CSS to achieve the same with different colors menus... Share some third party links so that we can explore the same. Thank in advance, Appreciate your quick response... Regards Suffian Ahmed
FYI -
http://jsfiddle.net/2HmUk/
http://themes.typepad.com/guide/2012/01/navbar-multi-color.html
Suffian Ahmed
FYI - http://jsfiddle.net/2HmUk/ http://themes.typepad.com/guide/2012/01/navbar-multi-color.html Regards Suffian Ahmed
You can use those tutorials and add that code into the Home >> Settings >> Additional CSS. Also use the !important; after each option like this:
color:red!important;
Hi, You can use those tutorials and add that code into the Home >> Settings >> Additional CSS. Also use the `!important;` after each option like this: color:red!important; Sincerely, Hella
How this thing works for me,
<ul>
    <li><a id="darkcyan" href="#">Link</a></li>
    <li><a id="darkgray" href="#">Link</a></li>
    <li><a id="skyblue" href="#">Link</a></li>
    <li><a id="coral" href="#">Link</a></li>
    <li><a id="sandybrown" href="#">Link</a></li>
    <li><a id="crimson" href="#">Link</a></li>
  </ul>
================CSS =============
nav ul li:nth-child(1) a { color: orange; }
nav ul li:nth-child(2) a { color: red; }
nav ul li:nth-child(3) a { color: green; }
nav ul li:nth-child(4) a { color: brown; }
nav ul li:nth-child(5) a { color: yellow; }
nav ul li:nth-child(6) a { color: purple; }
Suffian Ahmed
How this thing works for me, <ul> <li><a id="darkcyan" href="#">Link</a></li> <li><a id="darkgray" href="#">Link</a></li> <li><a id="skyblue" href="#">Link</a></li> <li><a id="coral" href="#">Link</a></li> <li><a id="sandybrown" href="#">Link</a></li> <li><a id="crimson" href="#">Link</a></li> </ul> ================CSS ============= nav ul li:nth-child(1) a { color: orange; } nav ul li:nth-child(2) a { color: red; } nav ul li:nth-child(3) a { color: green; } nav ul li:nth-child(4) a { color: brown; } nav ul li:nth-child(5) a { color: yellow; } nav ul li:nth-child(6) a { color: purple; } Regards Suffian Ahmed
<ul>
  </ul>
Is that above code, where i need to add it in the Themler ?
Suffian Ahmed
<ul> <li><a id="darkcyan" href="#">Link</a></li> <li><a id="darkgray" href="#">Link</a></li> <li><a id="skyblue" href="#">Link</a></li> <li><a id="coral" href="#">Link</a></li> <li><a id="sandybrown" href="#">Link</a></li> <li><a id="crimson" href="#">Link</a></li> </ul> ================CSS ============= nav ul li:nth-child(1) a { color: orange; } nav ul li:nth-child(2) a { color: red; } nav ul li:nth-child(3) a { color: green; } nav ul li:nth-child(4) a { color: brown; } nav ul li:nth-child(5) a { color: yellow; } nav ul li:nth-child(6) a { color: purple; } color:red!important; Is that above code, where i need to add it in the Themler ? Regards Suffian Ahmed
We used this to get the background color for different horizontal menus
nav ul li:nth-child(1) a { background: orange!Important; }
nav ul li:nth-child(2) a { background: red!Important; }
nav ul li:nth-child(3) a { background: green!Important; }
nav ul li:nth-child(4) a { backgrond: brown!Important; }
nav ul li:nth-child(5) a { background: yellow!Important; }
nav ul li:nth-child(6) a { background: purple!Important; }
nav ul li:nth-child(7) a { background: pink!Important; }
nav ul li:nth-child(8) a { background: skyblue!Important; }
Is this works for us? Attached screenshot for your reference...
This you can achieve using Themler too right as a default feature for menus. ?
Suffian Ahmed
We used this to get the background color for different horizontal menus nav ul li:nth-child(1) a { background: orange!Important; } nav ul li:nth-child(2) a { background: red!Important; } nav ul li:nth-child(3) a { background: green!Important; } nav ul li:nth-child(4) a { backgrond: brown!Important; } nav ul li:nth-child(5) a { background: yellow!Important; } nav ul li:nth-child(6) a { background: purple!Important; } nav ul li:nth-child(7) a { background: pink!Important; } nav ul li:nth-child(8) a { background: skyblue!Important; } Is this works for us? Attached screenshot for your reference... This you can achieve using Themler too right as a default feature for menus. ? Regards Suffian Ahmed
And, the above code is not working for sub menu, I am getting same sub-menu root color and submenu colors as same...
Find the screenshot attached, I like to add colors only for root menus and not to submenus.
Check the screenshot... Same colors even for menus and submenus of the same. Wh?
Suffian Ahmed
And, the above code is not working for sub menu, I am getting same sub-menu root color and submenu colors as same... Find the screenshot attached, I like to add colors only for root menus and not to submenus. Check the screenshot... Same colors even for menus and submenus of the same. Wh? Regards Suffian Ahmed
The code you created affects all a elements inside nav tree. The subitems are ul-li-a tree too. If you want to affect 1st level items only you need more specific selectors. For example:
nav ul.nav > li:nth-child(1) > a {...}
Hi, The code you created affects all `a` elements inside `nav` tree. The subitems are `ul-li-a` tree too. If you want to affect 1st level items only you need more specific selectors. For example: `nav ul.nav > li:nth-child(1) > a {...}` Thank you, Olivia
Hi Olivia,
The below code as per your suggestions is working for first menu and its sub menu but failed for next second sub menu and its root menu.
nav ul.nav > li:nth-child(1) a { background: orange!Important; }
nav ul.nav > li:nth-child(2) a { background: red!Important; }
nav ul.nav > li:nth-child(3) a { background: green!Important; }
nav ul.nav > li:nth-child(4) a { backgrond: brown!Important; }
nav ul.nav > li:nth-child(5) a { background: yellow!Important; }
nav ul.nav > li:nth-child(6) a { background: purple!Important; }
nav ul.nav > li:nth-child(7) a { background: pink!Important; }
nav ul.nav > li:nth-child(8) a { background: skyblue!Important; }
Kindly check the screenshot attached for your reference, please let us know how to apply nth-child of root menus of all main menus in horizontal menus only.
Suffian Ahmed
Hi Olivia, The below code as per your suggestions is working for first menu and its sub menu but failed for next second sub menu and its root menu. nav ul.nav > li:nth-child(1) a { background: orange!Important; } nav ul.nav > li:nth-child(2) a { background: red!Important; } nav ul.nav > li:nth-child(3) a { background: green!Important; } nav ul.nav > li:nth-child(4) a { backgrond: brown!Important; } nav ul.nav > li:nth-child(5) a { background: yellow!Important; } nav ul.nav > li:nth-child(6) a { background: purple!Important; } nav ul.nav > li:nth-child(7) a { background: pink!Important; } nav ul.nav > li:nth-child(8) a { background: skyblue!Important; } Kindly check the screenshot attached for your reference, please let us know how to apply nth-child of root menus of all main menus in horizontal menus only. Regards Suffian Ahmed
Hi Olivia,
Sorry, the below code of yours is working fine.
nav ul.nav > li:nth-child(1) > a { background: orange!Important; }
nav ul.nav > li:nth-child(2) > a { background: red!Important; }
nav ul.nav > li:nth-child(3) > a { background: green!Important; }
nav ul.nav > li:nth-child(4) > a { backgrond: brown!Important; }
nav ul.nav > li:nth-child(5) > a { background: yellow!Important; }
nav ul.nav > li:nth-child(6) > a { background: purple!Important; }
nav ul.nav > li:nth-child(7) > a { background: pink!Important; }
nav ul.nav > li:nth-child(8) > a { background: skyblue!Important; }
Appreciated your response, i missed out some of the script so got it wrong. Now, its working fine.
Suffian Ahmed
Hi Olivia, Sorry, the below code of yours is working fine. nav ul.nav > li:nth-child(1) > a { background: orange!Important; } nav ul.nav > li:nth-child(2) > a { background: red!Important; } nav ul.nav > li:nth-child(3) > a { background: green!Important; } nav ul.nav > li:nth-child(4) > a { backgrond: brown!Important; } nav ul.nav > li:nth-child(5) > a { background: yellow!Important; } nav ul.nav > li:nth-child(6) > a { background: purple!Important; } nav ul.nav > li:nth-child(7) > a { background: pink!Important; } nav ul.nav > li:nth-child(8) > a { background: skyblue!Important; } Appreciated your response, i missed out some of the script so got it wrong. Now, its working fine. Regards Suffian Ahmed
Support Team posted this 06 June 2018
Nice to hear that all is working fine now.
Hi, Nice to hear that all is working fine now. Sincerely, Hella
