show/hide a CMS field
Orange Gorilla
Orange Gorilla posted this 07 June 2018
Is there a possibility to show/hide a CMS field based on the users role?
I add a CMS clock in the template and add some code (Advanced custom field code).
It should be visible when a user is logged in.
Is there a possibility to show/hide a CMS field based on the users role? I add a CMS clock in the template and add some code (Advanced custom field code). It should be visible when a user is logged in.
Support Team posted this 08 June 2018
Themler does not have such functionality. You can try to insert the clock as the module from the Joomla admin and then use some Joomla tools to show that module for the logged in users only.
Hi, Themler does not have such functionality. You can try to insert the clock as the module from the Joomla admin and then use some Joomla tools to show that module for the logged in users only. Sincerely, Hella
Orange Gorilla
Orange Gorilla posted this 08 June 2018
Sorry
I mean block, not clock. Its a wordpress website.
Sorry I mean block, not clock. Its a wordpress website.
Actually the answer is the same. Themler does not control such functionality. Maybe there are some WP tools that will allow you to hide the widget for the certain users.
Hi, Actually the answer is the same. Themler does not control such functionality. Maybe there are some WP tools that will allow you to hide the widget for the certain users. Sincerely, Hella
