Video not showing wide screen, no loops, and doesnt hide play bar
mgarcia
mgarcia posted this 08 June 2018
Hello there,
Ive implemented this background video in my home page, so far so good.
However seems like my configuration is not working, I need to,
- Hide the play bar below the video
- Loop inifinetly
- Ive stretched the video, as you can see, but theres a gap at the left
By the other hand, not sure if it concerns, my video is webm format, it doesnt play on Safari, it asks for download
attached is a screenshot
Thanks in advance per your advice,
Martin
Hello there, Ive implemented this background video in my home page, so far so good. However seems like my configuration is not working, I need to, - Hide the play bar below the video - Loop inifinetly - Ive stretched the video, as you can see, but theres a gap at the left By the other hand, not sure if it concerns, my video is webm format, it doesnt play on Safari, it asks for download attached is a screenshot Thanks in advance per your advice, Martin
Support Team posted this 09 June 2018
Themler Video control is for Youtube and Vimeo videos. That's why the control's options do not affect the video you're using. It is inserted as it is. You need to remove everything you want to remove and enable Loop in the original video.
You specified 1600px max width for video control . Therefore on the larger screens you will see the gaps. But even if you remove it please note that the video you're using provides own settings. Themler can control the wrapper parameters in this case only.
Themler video control generates responsive iframe wrapper for the video file. With the same result you can use HTML control where you can insert any custom HTML which will work the same.
Hi, Themler Video control is for Youtube and Vimeo videos. That's why the control's options do not affect the video you're using. It is inserted as it is. You need to remove everything you want to remove and enable Loop in the original video. You specified 1600px max width for video *control* . Therefore on the larger screens you will see the gaps. But even if you remove it please note that the video you're using provides own settings. Themler can control the wrapper parameters in this case only. Themler video control generates responsive iframe wrapper for the video file. With the same result you can use HTML control where you can insert any custom HTML which will work the same. Thank you, Olivia
tmgarrison
tmgarrison posted this 09 October 2018
There are "host" of reasons people want to use video that is "NOT" uploaded to YouTube. I have customers who simply don't want all the things associated with YouTube in their business videos.
There must be an answer within Themler to provide the auto play and loop controls.
Are you suggesting to edit the Themler files through Joomla in order to address the lack of control?
Thanks.
Hi, There are "host" of reasons people want to use video that is "NOT" uploaded to YouTube. I have customers who simply don't want all the things associated with YouTube in their business videos. There must be an answer within Themler to provide the auto play and loop controls. Are you suggesting to edit the Themler files through Joomla in order to address the lack of control? Thanks.
tmgarrison
tmgarrison posted this 19 November 2018
I have another point.
Themler is supposed to be responsive with videos, but only as far as the wrapper.
Yet, when I have a YouTube video inserted, the Themler wrapper only works for Portrait.
When you turn a device Landscape, there is a large space under the video.
Any thoughts?
I have another point. Themler is supposed to be responsive with videos, but only as far as the wrapper. Yet, when I have a YouTube video inserted, the Themler wrapper only works for Portrait. When you turn a device Landscape, there is a large space under the video. Any thoughts?
spedytor.marinus
spedytor.marinus posted this 27 December 2018
I completely agree with the previous speaker. I do not want to use neither youtube nor vimeo. My clients want to keep theirs on their own servers. Why did you change the old good version for which you will not want to use in a moment?
