How to get @ and / symbols in Form Input Value
mauricejunior
mauricejunior posted this 3 weeks ago
I have a form on my website using the FormMail script. One of the hidden inputs requires the receiving email address, however whenever I enter the email address themler automatically removes the @ symbol, causing the script to fail.
Another hidden input for the Thank You page requires the page URL, however whenever I enter the URL themler automatically removes the / symbols, causing the script to fail.
How do I solve this
I have a form on my website using the FormMail script. One of the hidden inputs requires the receiving email address, however whenever I enter the email address themler automatically removes the @ symbol, causing the script to fail. Another hidden input for the Thank You page requires the page URL, however whenever I enter the URL themler automatically removes the / symbols, causing the script to fail. How do I solve this
Are you sure that this is the Themler issue? Have you tried to activate the non-Themler theme and see if that is working the same. It may be not Themler that is influencing the third-party form script.
Hi, Are you sure that this is the Themler issue? Have you tried to activate the non-Themler theme and see if that is working the same. It may be not Themler that is influencing the third-party form script. Sincerely, Hella
mauricejunior
mauricejunior posted this 2 weeks ago
I am speaking here of the themler interface for setting up a form. I attached 2 screenshots to show the problem.
In the first screenshot, the value I entered was "info@sailorswildernesstours.com", Themler automatically deleted the "@" as you can see it now reads "infosailorswildernesstours.com". This value then breaks the script because the script is looking for an email address, but themler has removed the "@".
In the second screenshot, the value I entered was "https://sailorswildernesstours.com", Themler automatically deleted the "://" as you can see it now reads "httpssailorswildernesstours.com". This value then breaks the script because the script is looking for a URL address, but themler has removed the "://".
Is this fixable?
I am speaking here of the themler interface for setting up a form. I attached 2 screenshots to show the problem. In the first screenshot, the value I entered was "info@sailorswildernesstours.com", Themler automatically deleted the "@" as you can see it now reads "infosailorswildernesstours.com". This value then breaks the script because the script is looking for an email address, but themler has removed the "@". In the second screenshot, the value I entered was "https://sailorswildernesstours.com", Themler automatically deleted the "://" as you can see it now reads "httpssailorswildernesstours.com". This value then breaks the script because the script is looking for a URL address, but themler has removed the "://". Is this fixable?
Unfortunately special characters like @ are forbidden for entering in all input fields in Themler UI as it may cause problems with Themler functionality. However you can use custom js to populate the value of this input with the desired content on page loading. This custom js can be added into Themler Settings >> Additional HEAD HTML field.
As alternative the same functionality with sending email to the hardcoded address can be described in the php action file you're using.
Hi, Unfortunately special characters like `@` are forbidden for entering in all input fields in Themler UI as it may cause problems with Themler functionality. However you can use custom js to populate the value of this input with the desired content on page loading. This custom js can be added into Themler Settings >> Additional HEAD HTML field. As alternative the same functionality with sending email to the hardcoded address can be described in the php action file you're using. Thank you, Olivia
