submenu width
hovmedia
hovmedia posted this 02 July 2018
Hi!
How do I get more space between the columns in the submenu under button "BUTIKK"? Try hover and you see that the fields overlaps each other.
http://www.tassmusszoo.no/butikk/
Hi! How do I get more space between the columns in the submenu under button "BUTIKK"? Try hover and you see that the fields overlaps each other. http://www.tassmusszoo.no/butikk/
Support Team posted this 03 July 2018
Unfortunately the width of the columns can be set only to the value that can be divided into 12 as we are using the Bootstrap 12-grid system. So if you have 6 columns, they can have bigger width, but the next step when making the column smaller is dividing it into 12. So you can choose only predefined values from the Horizontal Menu >> Columns >> Width menu.
Hi, Unfortunately the width of the columns can be set only to the value that can be divided into 12 as we are using the Bootstrap 12-grid system. So if you have 6 columns, they can have bigger width, but the next step when making the column smaller is dividing it into 12. So you can choose only predefined values from the Horizontal Menu >> Columns >> Width menu. Sincerely, Hella
