Safari not show normally responsive menu
Alexander Dzhuninski
Alexander Dzhuninski posted this 03 July 2018
When we open our site trough Safari browser on Iphone, responsive menu item stay transparent over slider under menu. When slider hide-up (scroll-up), menu appear normally
http://varna-new.itcanhelp.eu/
On other browser, work normally, how to fix it ?
When we open our site trough Safari browser on Iphone, responsive menu item stay transparent over slider under menu. When slider hide-up (scroll-up), menu appear normally http://varna-new.itcanhelp.eu/ On other browser, work normally, how to fix it ?
Support Team posted this 03 July 2018
HI,
Looks strange. The menu is located in the container and that container has the Sticky extension enabled right? Try to open the Sticky extension options in the right panel and set the position to relative and z-index property to 1000.
HI, Looks strange. The menu is located in the container and that container has the Sticky extension enabled right? Try to open the Sticky extension options in the right panel and set the position to `relative` and z-index property to `1000`. Sincerely, Hella
Ok, Thanks :)
Ok, Thanks :)
You are welcome. Let us know if you need our further help.
You are welcome. Let us know if you need our further help. Sincerely, Hella
