Remove Bullet points from plugin but not page
Jamie.D
Jamie.D posted this 06 July 2018
Themler is adding additional bullet points to a knowledge base plugin i have and it looks like this:
https://ibb.co/gt2ZXJ
I suspect some additional CSS would do the trick but I don't know CSS so can't figure out how to remove it properly, if i add the following CSS it removes it but it also removes it from the entire site and i want to keep bullet points on normal pages.
.bd-bulletlist li:after, .bd-bulletlist li:before, .bd-tagstyles:not(.bd-custom-bulletlist):not(.shape-only) ul:not([class*=menu]) li:after, .bd-tagstyles:not(.bd-custom-bulletlist):not(.shape-only) ul:not([class*=menu]) li:before {
content: none;}
With that CSS it looks good
https://ibb.co/c8OzXJ
But i would like to keep bullet point on pages too, which this doesn't.
Any ideas?
Cheers
Hi, Themler is adding additional bullet points to a knowledge base plugin i have and it looks like this: https://ibb.co/gt2ZXJ I suspect some additional CSS would do the trick but I don't know CSS so can't figure out how to remove it properly, if i add the following CSS it removes it but it also removes it from the entire site and i want to keep bullet points on normal pages. .bd-bulletlist li:after, .bd-bulletlist li:before, .bd-tagstyles:not(.bd-custom-bulletlist):not(.shape-only) ul:not([class*=menu]) li:after, .bd-tagstyles:not(.bd-custom-bulletlist):not(.shape-only) ul:not([class*=menu]) li:before { content: none;} With that CSS it looks good https://ibb.co/c8OzXJ But i would like to keep bullet point on pages too, which this doesn't. Any ideas? Cheers
9 Comments
Support Team posted this 06 July 2018
Please provide a link to the page where we could see the problem.
Hi, Please provide a link to the page where we could see the problem. Sincerely, Hella
Jamie.D
Sorry, It's actually an internally hosted site so no access outside of our network, can i maybe take a screenshot of something to assist?
OK, let's try it this way. Open youк site, right click on the list element with the bullet and open Inspect Element window. Then make a screen shot and attach it to the ticket.
Hi, OK, let's try it this way. Open youк site, right click on the list element with the bullet and open Inspect Element window. Then make a screen shot and attach it to the ticket. Sincerely, Hella
Jamie.D
thank you, Is this ok?
enter image description here
thank you, Is this ok? ![enter image description here][1] [1]: https://s8.postimg.cc/rjocfvnat/2018-07-06_11_07_28-.png
Unfortunately the image was compressed and I cannot define the class name to get the proper code. Could you please make a screen shot and upload it in this case directly with the attachment button or in some other way with no compression.
Hi, Unfortunately the image was compressed and I cannot define the class name to get the proper code. Could you please make a screen shot and upload it in this case directly with the attachment button or in some other way with no compression. Sincerely, Hella
Jamie.D
Same one attached using the attach button, does this help?
Same one attached using the attach button, does this help? !2018-07-06-11-07-28-.png!
Please try to add this code under the Home >> Settings >> Additional CSS:
.epkb-articles li:before
content:none!important;
Hi, Please try to add this code under the Home >> Settings >> Additional CSS: .epkb-articles li:before { content:none!important; } Sincerely, Hella
Jamie.D
Works perfect, thank you so much!
You are welcome. Nice to hear that is helped. Feel free to contact us again.
You are welcome. Nice to hear that is helped. Feel free to contact us again. Sincerely, Hella
