PHP version not high enough for wordpress to work correctly
lavisbre
lavisbre posted this 11 July 2018
Hello Team awsome
i cant get header file to work with GTM or bing or anything i add
tech support used a tool called "heath check" which clearly shows my php is old?
it said "PHP Version 5.6.30 - For best performance we recommend using PHP 7.2 or higher"
How do i remedy this issue, please.
Kind regards
Alan
Hello Team awsome i cant get header file to work with GTM or bing or anything i add tech support used a tool called "heath check" which clearly shows my php is old? it said "PHP Version 5.6.30 - For best performance we recommend using PHP 7.2 or higher" How do i remedy this issue, please. Kind regards Alan
Support Team posted this 11 July 2018
Hello Alan,
PHP version used on your hosting server doesn't depend on the theme used for the website, and not on Themler installed. You may need to contact your hosting provider with the issue.
Hello Alan, PHP version used on your hosting server doesn't depend on the theme used for the website, and not on Themler installed. You may need to contact your hosting provider with the issue. Sincerely, Nettie, BillionDigital Team
DaveOzric
DaveOzric posted this 11 July 2018
Perhaps he is talking about your Desktop Program PHP Version 5.4.42
Vitaliy WD
Vitaliy WD posted this 12 July 2018
The best way to work with Themler is use own local or web server (WAMP/ LAMP) with PHP 7. This can be Open Server or WampServer for Win. IMHO :)
lavisbre
lavisbre posted this 12 July 2018
its Ipage ... they have gone down hill and the tech is not very good
Support Team posted this 16 July 2018
Hello Alan,
Do you have the issue in Themler desktop? Or does it not work on the hosted website either?
Hello Alan, Do you have the issue in Themler desktop? Or does it not work on the hosted website either? Sincerely, Nettie, BillionDigital Team
