Get started: what is wrong? (New template starts with 404 page and not with Main page)
luca.anchini
luca.anchini posted this 11 July 2018
Hi all,
I want start from the beginning to understand well the mechanism of themler.
I've seen the video "Get Started with Joomla!" and I'm trying to do the same.
So I've run Themler --> Choose Joomla! ---> New template
The software running and at the end show me the 404 page to start to modify. If I choose, from the top bar menu, the Home page (but is the same if I choose it from the left column bar), the software bring me again to 404 page.
If I choose Article, Post, or Blog so it, finally, decide to show me the page I've chosen. But why not start from HOME (main) page?
Is there something to set into configuration or what?
Hi all, I want start from the beginning to understand well the mechanism of themler. I've seen the video "Get Started with Joomla!" and I'm trying to do the same. So I've run Themler --> Choose Joomla! ---> New template The software running and at the end show me the 404 page to start to modify. If I choose, from the top bar menu, the Home page (but is the same if I choose it from the left column bar), the software bring me again to 404 page. If I choose Article, Post, or Blog so it, finally, decide to show me the page I've chosen. But why not start from HOME (main) page? Is there something to set into configuration or what? Thank you
Support Team posted this 11 July 2018
Please try to update the theme to the latest version by clicking "1" in the circle on the top after you have the theme opened. Then save the theme and click F5. Is the issue still present?
Hello, Please try to update the theme to the latest version by clicking "1" in the circle on the top after you have the theme opened. Then save the theme and click F5. Is the issue still present? Sincerely, Nettie, BillionDigital Team
luca.anchini
Yes,
nothing change.
Yes, nothing change.
That is the desktop version you are using? Please open the Joomla admin and check the the current menu that is active on the site includes the Default Site item that is using the Home template. As explained here:
http://answers.themler.io/articles/36343/how-to-work-with-templates-in-joomla-themes
Hi, That is the desktop version you are using? Please open the Joomla admin and check the the current menu that is active on the site includes the Default Site item that is using the Home template. As explained here: http://answers.themler.io/articles/36343/how-to-work-with-templates-in-joomla-themes Sincerely, Hella
luca.anchini
To be precisely:
I've downloaded the joomla! blank template and installed it. It seems works good.
The problem I've written on is with the Windows version of themler.
To be precisely: I've downloaded the joomla! blank template and installed it. It seems works good. The problem I've written on is with the Windows version of themler.
Have you tried my recommendations from the post above?
Hi, Have you tried my recommendations from the post above? Sincerely, Hella
luca.anchini
Hi, yes, now it works, and I've understood why not before :)
> Hi, > > Have you tried my recommendations from the post above? > > Sincerely, > Hella Hi, yes, now it works, and I've understood why not before :) Thank you
Thanks for letting us know. As a rule, there is an item set as Home by default, but sometimes it can be necessary to set it in Joomla admin.
Hello, Thanks for letting us know. As a rule, there is an item set as Home by default, but sometimes it can be necessary to set it in Joomla admin. Sincerely, Nettie, BillionDigital Team
