WooCommerce List view as default
ZCompany
ZCompany posted this 19 July 2018
Hello!
Can you please tell me if it's possible to make the list view the default one for this site:
Изработка на сайтове, онлайн магазини
Currently the icons for grid/list view are removed. I tried with some codes I found in your forum, but those codes made the product slider items disappear.
Hello! Can you please tell me if it's possible to make the list view the default one for this site: [Изработка на сайтове, онлайн магазини][1] [1]: https://mysuper.site/%D0%BF%D0%B0%D0%BA%D0%B5%D1%82%D0%B8-%D0%B7%D0%B0-%D0%B8%D0%B7%D1%80%D0%B0%D0%B1%D0%BE%D1%82%D0%BA%D0%B0-%D0%BD%D0%B0-%D1%81%D0%B0%D0%B9%D1%82%D0%BE%D0%B2%D0%B5-%D0%BC%D0%B0%D0%B3%D0%B0%D0%B7%D0%B8/ Currently the icons for grid/list view are removed. I tried with some codes I found in your forum, but those codes made the product slider items disappear.
johnk6507
johnk6507 posted this 19 July 2018
Following
Following
Support Team posted this 25 July 2018
Sorry for the delay.
Unfortunately you cannot set the List view as Default. You can only configure Grid mode similar to List mode with one column layout. And then change List mode layout to columns. Unfortunately there is no option to change icons.
Hi, Sorry for the delay. Unfortunately you cannot set the List view as Default. You can only configure Grid mode similar to List mode with one column layout. And then change List mode layout to columns. Unfortunately there is no option to change icons. Thank you, Olivia
