Mobile menu text multilanguage?
kostianev
kostianev posted this 29 July 2018
Dear, I need to translate the Mobile Menu Text, for example I have 3 languages in my website and when add Menu text Menu, I need to translate this in other languages?
Vitaliy WD
Vitaliy WD posted this 29 July 2018
Hi.
You can try this: If you use Joomla then you can create language override (for example BT_RESP_MENU_LABEL="MenĂ¼") and then directly in Button Text field paste this code:
<?php echo JText::_( 'BT_RESP_MENU_LABEL' ); ?>
Hi. You can try this: If you use Joomla then you can create **language override** (for example `BT_RESP_MENU_LABEL="Menü"`) and then directly in **Button Text** field paste this code: <?php echo JText::_( 'BT_RESP_MENU_LABEL' ); ?>
kostianev
Hello, it`s working ;) Thank you!
