How can I disconnect Sidebar on Home and Post template?
jansen.marcus
jansen.marcus posted this 31 July 2018
On mij website "javadu.be" I defined a left sidebar for both home and post template.
They are identical.
But now I want to disconnect them, because I want to be able to hide the sidebar for the posts from the (smart)phone views to save some space.
Is there a way to resolve this?
Best regards,
Mark Jansen
Hi, On mij website "javadu.be" I defined a left sidebar **for both home and post template**. They are **identical**. ***But now I want to disconnect them***, because I want to be able to hide the sidebar for the posts from the (smart)phone views to save some space. Is there a way to resolve this? Best regards, Mark Jansen
6 Comments
Support Team posted this 01 August 2018
Hello Mark,
It is possible, to enable/disable a sidebar for a specific template, for this in the Sidebar tab select Show On [some template]. For the template it is shown on, it is possible to define in which modes the sidebar will be displayed, also in the Sidebar tab there is an option Display On - for example, click on Phones icon, to hide the sidebar in Phones mode.
Hello Mark, It is possible, to enable/disable a sidebar for a specific template, for this in the Sidebar tab select Show On [some template]. For the template it is shown on, it is possible to define in which modes the sidebar will be displayed, also in the Sidebar tab there is an option Display On - for example, click on Phones icon, to hide the sidebar in Phones mode. Sincerely, Nettie
jansen.marcus
jansen.marcus posted this 01 August 2018
Hello Nettie,
Thanks for the explanation.
I've still one problem. I don't see the "Show on".
The "Display on" is visible (see screenshot), but when disabling for phones f.i. this also occurs for al the other templates. That's what I don't want to happen.
Mark
Hello Nettie, Thanks for the explanation. I've still one problem. I don't see the "**Show on**". The "**Display on**" is visible (see screenshot), but when disabling for phones f.i. this also occurs for al the other templates. That's what I don't want to happen. Sincerely, Mark
Hello Mark,
Sorry for confusion. To switch a sidebar for a specific template, please go to the Content&Sidebars tab >> Sidebars and select a sidebar, then click on the little arrow to open a drop-down with templates.
Hello Mark, Sorry for confusion. To switch a sidebar for a specific template, please go to the Content&Sidebars tab >> Sidebars and select a sidebar, then click on the little arrow to open a drop-down with templates. Sincerely, Nettie
jansen.marcus
Nice,
But I still want to go a step further.
I would like to display the left sidebar on all my templates (home and post).
But I don't want to display the template on the phone view of a post and only a post.
That's what I'm finally looking for....
So that's why I thought I should try to disconnect both left sidebars from home and post so they are independent from each other and than I could hide the sidebar for just the phone view on a post without influencing the home template.
Mark
Nice, But I still want to go a step further. I would like to display the left sidebar on all my templates (home and post). *But I don't want to display the template on the phone view of a post and only a post.* That's what I'm finally looking for.... So that's why I thought I should try to disconnect both left sidebars from home and post so they are independent from each other and than I could hide the sidebar for just the phone view on a post without influencing the home template. Sincerely, Mark
jansen.marcus
jansen.marcus posted this 07 August 2018
Any news about this problem?
Mark
Hello, Any news about this problem? Regards, Mark
Support Team posted this 13 August 2018
Sorry for the delays. The Sidebars are special containers created to share its styles and content between templates. This is the main function of sidebars. And, unfortunately, this function cannot be disabled.
I have only one idea. If you know css you can add some custom css which will hide the sidebar in the phone mode directly on the template using HTML control. Add it somewhere on the template (at the top or at the bottom but not inside containers with orange border). Unfortunately there is no other way to achieve what you want.
Hi, Sorry for the delays. The Sidebars are special containers created to share its styles and content between templates. This is the main function of sidebars. And, unfortunately, this function cannot be disabled. I have only one idea. If you know css you can add some custom css which will hide the sidebar in the phone mode directly on the template using HTML control. Add it somewhere on the template (at the top or at the bottom but not inside containers with orange border). Unfortunately there is no other way to achieve what you want. Thank you, Olivia
