How to translate backwars links?
Webneshin
Webneshin posted this 08 August 2018
How to translate backward links?
Support Team posted this 10 August 2018
If you are using the plug-in to translate your site on the CMS, then the backlinks text should be also translated automatically.
In any case you can disable backlinks at all and insert your own text as the Text control.
Hi, If you are using the plug-in to translate your site on the CMS, then the backlinks text should be also translated automatically. In any case you can disable backlinks at all and insert your own text as the Text control. Sincerely, Hella
