Export Artisteer project and further work as a Themler project !?!?
Jørgen Hansen
Jørgen Hansen posted this 02 September 2014
Hello.
Are there a posibillity to export a Artisteer project and work further in Themler design and fx use e-commerce ?
Hello. Are there a posibillity to export a Artisteer project and work further in Themler design and fx use e-commerce ?
Support Team posted this 02 September 2014
Unfortunately this is not possible.
Artisteer is using its own framework. Themler is using bootstrap framework. You can't convert Artisteer project to Themler theme.
Hello Unfortunately this is not possible. Artisteer is using its own framework. Themler is using bootstrap framework. You can't convert Artisteer project to Themler theme. Thank you, Olivia
sonicthoughts
sonicthoughts posted this 03 September 2014
Wish you guys would work together better. Esp. with Drupal Bootstrap!
Support Team posted this 04 September 2014
We will consider your suggestion. But it is technically not possible to convert Artisteer themes into Themler format.
Drupal export is coming soon.
Hell
Hi, We will consider your suggestion. But it is technically not possible to convert Artisteer themes into Themler format. Drupal export is coming soon. Sincerely, Hell BillionDigital Team
pablo.colqui
pablo.colqui posted this 19 December 2015
Hi, I read a post where says that be export from Artisteer to Themler.
http://answers.themler.com/articles/16223
I reinstall the program but dont can be able to do that. It's this really possible?
Hi, I read a post where says that be export from Artisteer to Themler. http://answers.themler.com/articles/16223 I reinstall the program but dont can be able to do that. It's this really possible?
Support Team posted this 20 December 2015
Please make sure that you have installed the exact version mentioned in the article below:
http://answers.themler.com/articles/19107/themler-v1-0-59-desktop-installation-updated-and-joomla-artx-support-added-10-aug-2015
There should be the Themler option in the Export window. If it is not there, then please provide a screen shot of the Export window and the About window so we could see the exact version number you are using.
Hi, Please make sure that you have installed the exact version mentioned in the article below: http://answers.themler.com/articles/19107/themler-v1-0-59-desktop-installation-updated-and-joomla-artx-support-added-10-aug-2015 There should be the Themler option in the Export window. If it is not there, then please provide a screen shot of the Export window and the About window so we could see the exact version number you are using. Sincerely, Hella
tti2
tti2 posted this 02 February 2016
Hi, I have the same problem - no Themler on list .
Support Team posted this 02 February 2016
Please try to use this version:
http://files3.artisteer.com/Artisteer.4.3.0.60902.exe
Export to Themler should be present there.
Hello, Please try to use this version: http://files3.artisteer.com/Artisteer.4.3.0.60902.exe Export to Themler should be present there. Sincerely, Nettie, BillionDigital Team
