My work is nowhere to be found.
kingcryptofund
kingcryptofund posted this 28 August 2018
I have been working on an HTML theme, and saving it along the way just in case I needed to close out of the program. I've done this a few times and i have been able to pick up where I left off, but now when I open themler I must start from an "untitled" theme and i cannot find the one I was working on. Almost as if I never created it. Is there a way for me to get this back? I put in a lot of work into it and I know it was saved.
Support Team posted this 29 August 2018
The saved themes should be located at the path that is shown in the Theme Management screen after selecting some CMS, for example, C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\wordpress.
Try to copy the theme, zip-compress it and import it in Themler.
Hello, The saved themes should be located at the path that is shown in the Theme Management screen after selecting some CMS, for example, `C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\wordpress`. Try to copy the theme, zip-compress it and import it in Themler. Sincerely, Nettie
kingcryptofund
kingcryptofund posted this 29 August 2018
Thank you!
When I checked in C:\ProgramData\Themler\hd_data\ it seems the program automatically created another "themler_xxxxxxxxx" folder so that there were two. It was only reading from one folder even when I tried deleting the new one, I just took the html file from the old and copied it to the other and it works.
Thank you! When I checked in C:\ProgramData\Themler\hd_data\ it seems the program automatically created another "themler_xxxxxxxxx" folder so that there were two. It was only reading from one folder even when I tried deleting the new one, I just took the html file from the old and copied it to the other and it works.
I see, looks like something has influenced the installation so that the second folder was created - usually this happens by reinstallation of Themler desktop. In any case, thanks for letting us know and feel free to contact us if any other questions appear.
Hello, I see, looks like something has influenced the installation so that the second folder was created - usually this happens by reinstallation of Themler desktop. In any case, thanks for letting us know and feel free to contact us if any other questions appear. Sincerely, Nettie
