From bad to worse - how to log in?
webmaster261
webmaster261 posted this 4 weeks ago
Now I can longer log in. Are you trying to drive me nuts? It's working.....
Attempting to login now gives me
"account.themler.io’s server IP address could not be found."
enter image description here
Help!!!!
Now I can longer log in. Are you trying to drive me nuts? It's working..... Attempting to login now gives me "account.themler.io’s server IP address could not be found." ![enter image description here][1] Help!!!! [1]: http://crakatinny.com/images/Clipboard02.jpg
Sorry for the delay.
Does the issue continue?
Themler team
Hi, Sorry for the delay. Does the issue continue? Thank you, Themler team
webmaster261
webmaster261 posted this 3 weeks ago
It's driving me crazy.
It will work (if the snail pace of the thing can be called "work") for a little while. Usually when I go to save I get a prompt to log in (log in doesn't seem persistent).
What happens next is a lottery. Sometimes after a few minutes I get the cursor back. Other times the above message
When I go to export it really gets interesting; First, there is always a prompt to log in (why doesn't a log in stay persistent?)
Next, again a lottery. Other times, eventually after five or ten minutes (Seriously?!?!) the downloaded package appears.
This is just so bad as to be unusable.
Speedtest of my current connection:
https://testmy.net/db/ai1xwFuCE
It's driving me crazy. It will work (if the snail pace of the thing can be called "work") for a little while. Usually when I go to save I get a prompt to log in (log in doesn't seem persistent). What happens next is a lottery. Sometimes after a few minutes I get the cursor back. Other times the above message When I go to export it really gets interesting; First, there is always a prompt to log in (why doesn't a log in stay persistent?) Next, again a lottery. Other times, eventually after five or ten minutes (Seriously?!?!) the downloaded package appears. This is just so bad as to be unusable. Speedtest of my current connection: https://testmy.net/db/ai1xwFuCE
Sorry for the issue, it sounds quite strange. Please try to disable your anti virus application and firewall and see if that helps.
Hi, Sorry for the issue, it sounds quite strange. Please try to disable your anti virus application and firewall and see if that helps. Sincerely, Hella
