Different call-to-action section on different pages
Seppe
Seppe posted this 02 September 2018
Good evening
Is it possible to have different call-to-action sections of different pages?
The problem is that evere page on the website, uses the template "page".
But for 5 different pages on my website, I want a different call-to-action sections.
At this moment, all 5 sections appear on all pages.
Is it possible?
Or do I ask to much of the software?
Greetings
Seppe
Good evening Is it possible to have different call-to-action sections of different pages? The problem is that evere page on the website, uses the template "page". But for 5 different pages on my website, I want a different call-to-action sections. At this moment, all 5 sections appear on all pages. Is it possible? Or do I ask to much of the software? Greetings Seppe
shaulhadar
shaulhadar posted this 03 September 2018
Hi Seppe,
you can achieve this by duplicating the page template 5 times, and in each different template to put a different CTA.
Than just choose the right page template inside WP so you can have the CTA you want...
Hi Seppe, you can achieve this by duplicating the page template 5 times, and in each different template to put a different CTA. Than just choose the right page template inside WP so you can have the CTA you want...
Seppe
Seppe posted this 03 September 2018
Good morning Shaulhadar.
I'm using Joomla, but I guess it is the same.
This will also mean, that if I'm changing something in my template, I have to do this 5 times, just because of the CTA?
-> a loss of time and effort
Greetings
Good morning Shaulhadar. I'm using Joomla, but I guess it is the same. This will also mean, that if I'm changing something in my template, I have to do this 5 times, just because of the CTA? -> a loss of time and effort Greetings
shaulhadar
Hi Seppe,
This means that if you do it , you will have 5 different page templates, each one with a different CTA.
If you want to change afterwards anything, you can just change it in the page template itself.
you will not need to change it in other templates, as soon as you have them, changes will be made only in the template you are editing .
Hi Seppe, This means that if you do it , you will have 5 different page templates, each one with a different CTA. If you want to change afterwards anything, you can just change it in the page template itself. you will not need to change it in other templates, as soon as you have them, changes will be made only in the template you are editing .
Support Team posted this 05 September 2018
Why don't you want to insert the desired sections into the content of the corresponding pages? if it is not possible then a custom template is a better solution if you want to use exactly Themler Sections.
Hi, Why don't you want to insert the desired sections into the content of the corresponding pages? if it is not possible then a custom template is a better solution if you want to use exactly Themler Sections. Thank you, Olivia
Seppe
Seppe posted this 05 September 2018
Good evening Hella
Because the "corresponding pages" are all in the template "page".
So if I put it on 1 of my pages, it come to all my pages.
And THAT is not what I want :)
Greetings
Seppe
Good evening Hella Because the "corresponding pages" are all in the template "page". So if I put it on 1 of my pages, it come to all my pages. And THAT is not what I want :) Greetings Seppe
Seppe
Hi Seppe,
Good evening
I tried that, with the 5 different pages, but it doesn't work in Joomla.
For Joomla, I need to create 5 different templates, because I have to select the themplate needed for that specific page.
That is the whole point, it is so much more work.
greetings
Seppe
> Hi Seppe, > This means that if you do it , you will have 5 different page templates, each one with a different CTA. > > If you want to change afterwards anything, you can just change it in the page template itself. > you will not need to change it in other templates, as soon as you have them, changes will be made only in the template you are editing . Good evening I tried that, with the 5 different pages, but it doesn't work in Joomla. For Joomla, I need to create 5 different templates, because I have to select the themplate needed for that specific page. That is the whole point, it is so much more work. greetings Seppe
Seppe
Fixed it!
Fixed it! Thanks
