Error in Shortcode CSS
arsov
arsov posted this 04 September 2018
I'm trying to insert this shortcode into Shortcode CSS window and got an error message, some error in the first line.
Invalid style expected...
[sonaar_audioplayer show_playlist="true" show_track_market="true" show_album_market="true"][/sonaar_audioplayer]
Thanks in advance for your answer
Hi I'm trying to insert this shortcode into Shortcode CSS window and got an error message, some error in the first line. Invalid style expected... [sonaar_audioplayer show_playlist="true" show_track_market="true" show_album_market="true"][/sonaar_audioplayer] Thanks in advance for your answer
Support Team posted this 05 September 2018
Could you please provide the screenshot that demonstrates exactly where you're trying to insert the shortcode? All CSS fields are for CSS code only. Exactly where you want to insert this shortcode (content or widget)? In general, for Shortcodes there is Shortcodes control located under the Insert tab >> More.
Hi, Could you please provide the screenshot that demonstrates exactly where you're trying to insert the shortcode? All CSS fields are for CSS code only. Exactly where you want to insert this shortcode (content or widget)? In general, for Shortcodes there is Shortcodes control located under the Insert tab >> More. Thank you, Olivia
arsov
arsov posted this 05 September 2018
At the moment I inserted the widget and added shortcode as a text. When I inserted Shortcode and added shortcode into shortcode CSS (as I'm not sure where else should I put shortcode, I got the error from the picture.
Here is the link to the side http://unhappy-music.net/
Player is inserted through the widget instead of Shortcode layer. ( but it intend to be on the same place.
Thanks in advance for your answer.
Alex
At the moment I inserted the widget and added shortcode as a text. When I inserted Shortcode and added shortcode into shortcode CSS (as I'm not sure where else should I put shortcode, I got the error from the picture. Here is the link to the side http://unhappy-music.net/ Player is inserted through the widget instead of Shortcode layer. ( but it intend to be on the same place. http://unhappy-music.net/ Thanks in advance for your answer. Alex
Hello Alex,
CSS Insert wouldn't accept shortcode you ahve added, this is normal behavior.
If you don't see "Insert Shortcode" control under Insert -> More, then add showrcodes either inside Text field or inside HTML control.
Hello Alex, CSS Insert wouldn't accept shortcode you ahve added, this is normal behavior. If you don't see "Insert Shortcode" control under Insert -> More, then add showrcodes either inside Text field or inside HTML control. Gina Themler Support
arsov
arsov posted this 06 September 2018
Thanks for this answer. I inserted Shortcode layer through Insert Shorcode inside the container, but can't insert code inside, the only way is to open Shortcode Css and put there my shortcode. I'm doing probably something wrong, but can't find my way out.
and in the meantime I run on some other problem. On my other pages, all except main, I deleted this page layer and now I can't add content on those pages, as my Page template doesn't have this green Page area at the right and don't know how to get it back. I try to make new Custom template, but when I apply it to the page it doesn't show content on that page.....
Please help. :-)
Thanks for this answer. I inserted Shortcode layer through Insert Shorcode inside the container, but can't insert code inside, the only way is to open Shortcode Css and put there my shortcode. I'm doing probably something wrong, but can't find my way out. and in the meantime I run on some other problem. On my other pages, all except main, I deleted this page layer and now I can't add content on those pages, as my Page template doesn't have this green Page area at the right and don't know how to get it back. I try to make new Custom template, but when I apply it to the page it doesn't show content on that page..... Please help. :-)
