Product Zoom Window
css
css posted this 11 September 2018
Hi Support
I have a problem with product zoom window!
If you click on this link you see at product page for at display module (It is the same for all products)!
https://www.proces-data.com/product/pd-688-display/
  1. Please scroll a little bit down on the page!
  2. Then go to the topmenu and select products
  3. The maxmenu will fold down
  4. Then try choosing a product in the second column under INDUSTRIAL CONTROL MODULES eg. SENSORS
  5. When you move the cursor over SENSORS the menu closes and returns to the Product Zoom Window
What is wrong?
And please make it possible to disable the zoom function and change it to a lightbox option ;-)
Claus Springborg
**Hi Support** I have a problem with product zoom window! If you click on this link you see at product page for at display module (It is the same for all products)! https://www.proces-data.com/product/pd-688-display/ 1. Please scroll a little bit down on the page! 2. Then go to the topmenu and select products 3. The maxmenu will fold down 4. Then try choosing a product in the second column under INDUSTRIAL CONTROL MODULES eg. SENSORS 5. When you move the cursor over SENSORS the menu closes and returns to the Product Zoom Window What is wrong? And please make it possible to disable the zoom function and change it to a lightbox option ;-) Regards Claus Springborg
Support Team posted this 11 September 2018
Your header has the Sticky extension. Open that extension options in the right panel and set the z-index property to 10000.
Unfortunately there is no possibility to switch off the cloudzoom option.
Hi, Your header has the Sticky extension. Open that extension options in the right panel and set the z-index property to 10000. Unfortunately there is no possibility to switch off the cloudzoom option. Sincerely, Hella
css
css posted this 12 September 2018
Hi Hella
Thanks for quick support... It works ;_)
/Claus
Hi Hella Thanks for quick support... It works ;_) /Claus
Support Team posted this 12 September 2018
Nice to hear that. Feel free to contact us in any other occasion.
Hi, Nice to hear that. Feel free to contact us in any other occasion. Sincerely, Hella
