Insert - Image + Text
raffe
raffe posted this 11 September 2018
I have question about Insert - Image + Text,
how should I set the text next to the image so that the text is centered next the image and not on the line.
Hello, I have question about Insert - Image + Text, how should I set the text next to the image so that the text is centered next the image and not on the line. Thank you
Support Team posted this 11 September 2018
Sorry, I do not understand how exactly you want to position the text. Please attach a screen shot explaining what you want to achieve.
Hi, Sorry, I do not understand how exactly you want to position the text. Please attach a screen shot explaining what you want to achieve. Sincerely, Hella
raffe
I added example
I added example
Hello Rafal,
When you add Image+Text there are two fields next to the image: Header and Content line.
You must have added the text only to Header line. Try using Content line instead, it is centered:
Hello Rafal, When you add Image+Text there are two fields next to the image: Header and Content line. You must have added the text only to Header line. Try using Content line instead, it is centered: !image-text.png! Gina Themler Support
raffe
raffe posted this 12 September 2018
