Artisteer Export
rshboston
rshboston posted this 17 September 2018
I can no longer export from Artisteer. Apparently, it's because your server at 54.218.114.90 is down. When will this be resolved?
Bayern
Bayern posted this 18 September 2018
same problem
please fix urgently
same problem please fix urgently
Support Team posted this 18 September 2018
We are terribly sorry for the issue. The problem should be fixed within one day. Sorry again for the inconvenience.
Hi, We are terribly sorry for the issue. The problem should be fixed within one day. Sorry again for the inconvenience. Sincerely, Hella
rshboston
rshboston posted this 18 September 2018
I just tried exporting and it did not work.
Yes. it still does not work. As I have said above, we need one day to fix the issue.
Hi, Yes. it still does not work. As I have said above, we need one day to fix the issue. Sincerely, Hella
rshboston
So you meant within 24 hours, right? It should take approx 12 hours more to be resolved?
Support Team posted this 19 September 2018
The issue is fixed, let us know if it is still present for you.
Hello, The issue is fixed, let us know if it is still present for you. Sincerely, Nettie
rshboston
rshboston posted this 19 September 2018
Thank you!
Thank you!
