Cant open themler "Retry" PopUp
Malinka
Malinka posted this 01 October 2018
Cant open themler error message "Retry" PopUp
Best regards
Malinka
Hi Cant open themler error message "Retry" PopUp Best regards Malinka
14 Comments
Support Team posted this 01 October 2018
Please try temporarily disabling firewall, antivirus and add-ons for the Chrome browser. If the issue is still present, please let us know if the issue is present with a particular CMS or no matter what CMS is selected.
Hello, Please try temporarily disabling firewall, antivirus and add-ons for the Chrome browser. If the issue is still present, please let us know if the issue is present with a particular CMS or no matter what CMS is selected. Sincerely, Nettie
Malinka
I have test and yes it works on live site but not on localhost and not when i map an ip to a domain in host file windows 10.
It worked good yesterday have you changed something?
Best regards
Malinka
Hi I have test and yes it works on live site but not on localhost and not when i map an ip to a domain in host file windows 10. It worked good yesterday have you changed something? Best regards Malinka
Malinka
Ah sry i disabled a firewall filter i setup some days ago and now it is working sry again.
Thanks for letting us know. Please feel free to contact us in any other case.
Thanks for letting us know. Please feel free to contact us in any other case. Sincerely, Nettie
antokon82
antokon82 posted this 06 November 2018
Hello.
I'm having the same problem (Joomla attempt). Reinstalling the newer version did nothing. (Win 10). Any ideas?
Best regards,
Antony
Hello. I'm having the same problem (Joomla attempt). Reinstalling the newer version did nothing. (Win 10). Any ideas? Best regards, Antony
Support Team posted this 06 November 2018
Hi Antony,
Could you please try to rename the following folder into joomla-old and try to run Themler once again:
C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\joomla
Hi Antony, Could you please try to rename the following folder into **joomla-old** and try to run Themler once again: C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\joomla Sincerely, Nettie
antokon82
antokon82 posted this 07 November 2018
Hi Antony,
Unfortunately I still get the retry pop up window. The weird thing is when i type the address in Chrome "127.0.0.1:12080/themler_xxxxxxxxx\joomla\" it shows the demo template.
> Hi Antony, > > Could you please try to rename the following folder into **joomla-old** and try to run Themler once again: > > C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\joomla > > Sincerely, > Nettie > > Unfortunately I still get the retry pop up window. The weird thing is when i type the address in Chrome "127.0.0.1:12080/themler_xxxxxxxxx\joomla\" it shows the demo template.
Support Team posted this 07 November 2018
1. Backup all theme folders somewhere on your computer if there are any. The path is shown in the Theme Management screen after selecting some CMS, for example, C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\joomla.
7. Download latest version of Themler for Windows from themler.io, install it and try to start with Themler for Joomla and create a theme.
Hello, Please follow the steps below: 1. Backup all theme folders somewhere on your computer if there are any. The path is shown in the Theme Management screen after selecting some CMS, for example, `C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\joomla`. 2. Uninstall Themler completely and also check the box for "Remove all CMS content". 3. Check if the following folders are still present: C:\Program Files (x86)\Themler C:\ProgramData\Themler 4. If they exist, remove them. 5. Reboot the machine after uninstalling Themler, so that all Themler services are removed for sure. 6. Temporarily disable antivirus and firewall. 7. Download latest version of Themler for Windows from themler.io, install it and try to start with Themler for Joomla and create a theme. Please let us know the result. Sincerely, Nettie
antokon82
I did exactly what you described. The behavior is the same.
> Hello, > > Please follow the steps below: > 1. Backup all theme folders somewhere on your computer if there are any. The path is shown in the Theme Management screen after selecting some CMS, for example, `C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\joomla`. > 2. Uninstall Themler completely and also check the box for "Remove all CMS content". > 3. Check if the following folders are still present: > > C:\Program Files (x86)\Themler > C:\ProgramData\Themler > 4. If they exist, remove them. > 5. Reboot the machine after uninstalling Themler, so that all Themler services are removed for sure. > 6. Temporarily disable antivirus and firewall. > 7. Download latest version of Themler for Windows from themler.io, install it and try to start with Themler for Joomla and create a theme. > Please let us know the result. > > Sincerely, > Nettie > > I did exactly what you described. The behavior is the same.
Please try to run this URL in Chrome or Firefox browser:
http://127.0.0.1:12080/themler_1525116915/startup
and then select Joomla. Does the issue appear?
Hello, Please try to run this URL in Chrome or Firefox browser: http://127.0.0.1:12080/themler_1525116915/startup and then select Joomla. Does the issue appear? Sincerely, Nettie
antokon82
http://127.0.0.1:12080/themler_1840277635/startup/
shows "Choose a CMS to Run with Themler"
and after pressing on Joomla Same retry pop up
http://127.0.0.1:12080/themler_1840277635/startup/ shows "Choose a CMS to Run with Themler" and after pressing on Joomla Same retry pop up
Support Team posted this 08 November 2018
It can happen that antivirus or firewall are not disabled completely even if stopping them and are blocking/removing necessary files.
Please try to add the following folder to your antivirus/firewall white list:
C:\Program Files (x86)\Themler\
and try to install and run Themler for Joomla once again.
Hello, It can happen that antivirus or firewall are not disabled completely even if stopping them and are blocking/removing necessary files. Please try to add the following folder to your antivirus/firewall white list: C:\Program Files (x86)\Themler\ C:\ProgramData\Themler and try to install and run Themler for Joomla once again. Sincerely, Nettie
admin34
admin34 posted this 08 November 2018
You will not help me. This problem has been going on for over three weeks. It has now been 5 days since I responded to your last solution which didn't work. this is very disappointing your chose to go down this path.
I gave you 24 hours to comment on my problem you have not. You have left me no choose but to tell my story to the world, that your support is very bad.
You will not help me. This problem has been going on for over three weeks. It has now been 5 days since I responded to your last solution which didn't work. this is very disappointing your chose to go down this path. I gave you 24 hours to comment on my problem you have not. You have left me no choose but to tell my story to the world, that your support is very bad.
Support Team posted this 09 November 2018
admin34,
We have answered to your initial topic, please check it now.
admin34, We have answered to your initial topic, please check it now. Sincerely, Nettie
