Flex Box possible?
rock'n'popmuseum
rock'n'popmuseum posted this 02 October 2018
we dont manage it to build flex-boxes like you see at the following websites:
http://fliesen-dedaj.de/
https://www.boros.de/ (look at "clients")
I found a function "flex" under the columns but I dont have any idea how it works? I tried but I didnt manage to make it proper.
So, my question: Are flex-boxes like you see in the example possiple?
For example you move the mouse over a headline and more text will expand under the headline?
If yes, is there a turorial or can you maybe give me a short hint how I can do it?
Thanks a lot for help,
Frank
Hello, we dont manage it to build flex-boxes like you see at the following websites: http://fliesen-dedaj.de/ https://www.boros.de/ (look at "clients") I found a function "flex" under the columns but I dont have any idea how it works? I tried but I didnt manage to make it proper. So, my question: Are flex-boxes like you see in the example possiple? For example you move the mouse over a headline and more text will expand under the headline? If yes, is there a turorial or can you maybe give me a short hint how I can do it? Thanks a lot for help, Frank
Vitaliy WD
Vitaliy WD posted this 02 October 2018
Hi.
This is not about flexbox. You need overlay effects like this.
Hi. This is not about flexbox. You need overlay effects like [this][1]. [1]: http://bdthemes.net/demo/joomla/shortcode/en/shortcodes/trailer-box.html
rock'n'popmuseum
rock'n'popmuseum posted this 03 October 2018
Thanks. And is that effect possible with Themler?
rock'n'popmuseum
rock'n'popmuseum posted this 24 October 2018
Hello. no answer?
Hello. no answer?
Support Team posted this 14 December 2018
Hello Frank,
I apologize for the delay in reply.
Themler doesn't have exactly same feature as your exampl but it has Hover Box:
https://answers.themler.io/articles/8397/hover-box
You can create similar boxes as Vitaliy provided as an example.
When you insert a hover box, switch between Back Slide and Over Slide to change them.
You can add images to the backgound of both slides, add text to them as well (via Insert menu option).
You can also apply animation effects to the box in general.
Hello Frank, I apologize for the delay in reply. Themler doesn't have exactly same feature as your exampl but it has Hover Box: https://answers.themler.io/articles/8397/hover-box You can create similar boxes as Vitaliy provided as an example. When you insert a hover box, switch between Back Slide and Over Slide to change them. You can add images to the backgound of both slides, add text to them as well (via Insert menu option). You can also apply animation effects to the box in general. Gina Themler Support
