can't find footer.php in Joomla
tersia
tersia posted this 07 October 2018
I would like to add adword conversion code to my Joomla footer.php file, but I cant find where it is located.
Could you please advise where the file is located or other ways to insert the code?
I would like to add adword conversion code to my Joomla footer.php file, but I cant find where it is located. Could you please advise where the file is located or other ways to insert the code?
Support Team posted this 08 October 2018
As far as I know, you can add adwords code to head tags as well. You can check it with google instructions and if it works, add the code in Themler -> Home -> Settings -> Additional Head HTML.
If you want to add it to the footer tags, open theme files -> "templates" folder inside of it -> and open each php file in this folder, scroll down and find
tag there.
Hello, As far as I know, you can add adwords code to head tags as well. You can check it with google instructions and if it works, add the code in Themler -> Home -> Settings -> Additional Head HTML. If you want to add it to the footer tags, open theme files -> "templates" folder inside of it -> and open each php file in this folder, scroll down and find <footer> tag there. Gina Themler Support
