Dynamic slider height based on image
Porrey
Porrey posted this 16 October 2018
Hello, I want that my sliders height changes dynamic, based on the containing image. Like a fully responsive slider.
I found this link http://answers.themler.io/questions/121705/slider-height-auto but how can I do it in Themler 319?
Hello, I want that my sliders height changes dynamic, based on the containing image. Like a fully responsive slider. I found this link http://answers.themler.io/questions/121705/slider-height-auto but how can I do it in Themler 319?
Support Team posted this 29 October 2018
Hello Torsten,
I apologize for the delay in reply.
Yes, you should be able to do same. When adding the slide, insert image not via Slider -> Image option in the menu, but click inside the slider and go to Isert -> Image:
When image is inserted, click on it and select No Align positioning as described in the post you have already found on forum:
Hello Torsten, I apologize for the delay in reply. Yes, you should be able to do same. When adding the slide, insert image not via Slider -> Image option in the menu, but click inside the slider and go to Isert -> Image: !insert-image.png! When image is inserted, click on it and select No Align positioning as described in the post you have already found on forum: !no-align.png! Gina Themler Support
