Themler will not work with latest Joomla 3.9.0 update
tmgarrison
tmgarrison posted this 30 October 2018
The latest Joomla update to 3.9.0 is not allowing Themler to access the server. So Themler is NOT usable in any site that has Joomla updated to the latest version.
Once Joomla is updated there is NO returning to the previous version.
So there is no way to access Themler - I'm locked out of Themler until there is a fix.
Please see - http://answers.themler.io/questions/164207/unable-to-login-in-themler?page=1
The latest Joomla update to 3.9.0 is not allowing Themler to access the server. So Themler is NOT usable in any site that has Joomla updated to the latest version. Once Joomla is updated there is NO returning to the previous version. So there is no way to access Themler - I'm locked out of Themler until there is a fix. Please see - http://answers.themler.io/questions/164207/unable-to-login-in-themler?page=1
16 Comments
Support Team posted this 30 October 2018
We are sorry for the issue. We will try to fix it as soon as possible and will update this topic as soon as it is fixed.
Hello, We are sorry for the issue. We will try to fix it as soon as possible and will update this topic as soon as it is fixed. Sincerely, Nettie
enanzer
enanzer posted this 30 October 2018
same problem like tmgarrison, cannot open themler anymore since joomla 3.9.0 :-(
richard25
richard25 posted this 30 October 2018
Same issue here. Themler is not working in 3.9
sibren
sibren posted this 30 October 2018
same issue here
same issue here
pk
pk posted this 30 October 2018
Same issue here.
Same issue here.
Ivan_Krypt
Ivan_Krypt posted this 30 October 2018
Me too :-( i go crazy. ahhhh help help dear Themler Team ! (picture in Attachement) only white blank pop up when i will start themler under Joomla 3.9
Fjallis
Fjallis posted this 30 October 2018
Come on, please fix it!
Seppe
Seppe posted this 30 October 2018
since they focus on Nicepage, I guess it will take a long time
wanted to throw a website online tonight .... guess it has to wait now...
since they focus on Nicepage, I guess it will take a long time wanted to throw a website online tonight .... guess it has to wait now...
Vitaliy WD
Vitaliy WD posted this 30 October 2018
toolbar.php has been removed from Joomla 3.9 (since Joomla 3.9 Alpha)...
I am surprised that Themler developers not test beta releases of CMS on compatibility...
Here is this issue at Joomla! Issue Tracker: https://issues.joomla.org/tracker/joomla-cms/21960
`toolbar.php` has been removed from Joomla 3.9 (**since Joomla 3.9 Alpha**)... I am surprised that Themler developers not test beta releases of CMS on compatibility... Here is this issue at Joomla! Issue Tracker: https://issues.joomla.org/tracker/joomla-cms/21960
sibren
indeed, if I copy toolbar.php from a 3.8.13 Joomla installation into the folder ./administrator/includes/ then it works again. Thanks for the tip @Vitaly WD
For your convenience: I have attached the file I have used for the fix
indeed, if I copy toolbar.php from a 3.8.13 Joomla installation into the folder ./administrator/includes/ then it works again. Thanks for the tip @Vitaly WD For your convenience: I have attached the file I have used for the fix
Support Team posted this 31 October 2018
Hi everyone,
We're preparing the update with the fix for this issue. It will be available ASAP.
In addition to this, we'll provide an instruction on what php files should be changed in order to start Themler and update it if you already updated Joomla. Those who have not yet installed the updated Joomla will just need to update Themler first.
We apologize for the inconvenience.
Hi everyone, We're preparing the update with the fix for this issue. It will be available ASAP. In addition to this, we'll provide an instruction on what php files should be changed in order to start Themler and update it if you already updated Joomla. Those who have not yet installed the updated Joomla will just need to update Themler first. We apologize for the inconvenience. Sincerely, Olivia
johann9
johann9 posted this 31 October 2018
Hi everyone,
Thank you!
> Hi everyone, > > We're preparing the update with the fix for this issue. It will be available ASAP. > In addition to this, we'll provide an instruction on what php files should be changed in order to start Themler and update it if you already updated Joomla. Those who have not yet installed the updated Joomla will just need to update Themler first. > > We apologize for the inconvenience. > > Sincerely, > Olivia Thank you!
johann9
Thanks, this fixed my problem
> indeed, if I copy toolbar.php from a 3.8.13 Joomla installation into the folder ./administrator/includes/ then it works again. Thanks for the tip @Vitaly WD > For your convenience: I have attached the file I have used for the fix Thanks, this fixed my problem
The new update is here!
https://answers.themler.io/questions/173622/themler-hotfix-update-v-472-update-31-oct-2018
If you already updated Joomla to version 3.9 and encountered a problem with launching Themler please follow this instruction and then update Themler.
Hi, The new update is here! https://answers.themler.io/questions/173622/themler-hotfix-update-v-472-update-31-oct-2018 If you already updated Joomla to version 3.9 and encountered a problem with launching Themler please follow [this instruction](page:173620) and then update Themler. Sincerely, Olivia
online9
online9 posted this 08 December 2018
I have updated to 3.9 and was getting a 500 error as follows when opening themler from the J! template page.:
VM1357 jquery.js:9632 POST https://martinboroughfair.org.nz/templates/untitled/app/index.php 500 (Internal Server Error)
send @ VM1357 jquery.js:9632
ajax @ VM1357 jquery.js:9177
(anonymous) @ index.php?option=com…yout=edit&id=12:475
dispatch @ VM1357 jquery.js:4642
elemData.handle @ VM1357 jquery.js:4310
The fix also solved this.
I have updated to 3.9 and was getting a 500 error as follows when opening themler from the J! template page.: VM1357 jquery.js:9632 POST https://martinboroughfair.org.nz/templates/untitled/app/index.php 500 (Internal Server Error) send @ VM1357 jquery.js:9632 ajax @ VM1357 jquery.js:9177 (anonymous) @ index.php?option=com…yout=edit&id=12:475 dispatch @ VM1357 jquery.js:4642 elemData.handle @ VM1357 jquery.js:4310 The fix also solved this.
Support Team posted this 11 December 2018
Hi Paul,
That's great!
Please feel free to contact us if you have any further questions.
Ivan
Hi Paul, That's great! Please feel free to contact us if you have any further questions. Thanks, Ivan
