Themler HotFix Update v.472 Update (31-Oct-2018)
Support Team posted this 31 October 2018
Hi everyone,
This HotFix update includes the following fixes:
  • Joomla 3.9 compatibility.
    If you already updated Joomla to version 3.9 and encountered a problem with launching Themler please follow this instruction and then update Themler;
  • Fixed issue with shortcodes;
  • Fixed issue with 404 templates in Joomla themes in Themler Desktop.
Themler Team
Hi everyone, This HotFix update includes the following fixes: - Joomla 3.9 compatibility. If you already updated Joomla to version 3.9 and encountered a problem with launching Themler please follow [this instruction](page:173620) and then update Themler; - Fixed issue with shortcodes; - Fixed issue with 404 templates in Joomla themes in Themler Desktop. Sincerely, Themler Team
32 Comments
pdg.design
pdg.design posted this 31 October 2018
Great!
it work now. Thank you!
Great! it work now. Thank you!
Najemca
Najemca posted this 31 October 2018
thank you for the quick response Themler the best in the world
Runningman
Runningman posted this 31 October 2018
Thanks, works for all my Joomla sites!
Vitaliy WD
Vitaliy WD posted this 31 October 2018
Please note, that at http://themler.io/download is still old version 456, so if you download it and install it on fresh Joomla 3.9 you can't edit theme without code modification in source files.
Themler team, please update blank theme.
Please note, that at http://themler.io/download is still old version 456, so if you download it and install it on fresh Joomla 3.9 you can't edit theme without code modification in source files. **Themler team, please update blank theme.**
CATSS
CATSS posted this 01 November 2018
Hallo, hier ist der Pfad zu dem app Ordner von dem Template. Der in der Anleitung beschriebene Pfad ist missverständlich.
"Ordner wo Joomla installiert ist / templates / Name des Templates / " und dann den app Ordner aufrufen.
Hello, here is the path to the app folder of the template. The path described in the manual is misleading.
"Folder where Joomla is installed / templates / name of the template /" and then go in the app folder.
Hallo, hier ist der Pfad zu dem app Ordner von dem Template. Der in der Anleitung beschriebene Pfad ist missverständlich. "Ordner wo Joomla installiert ist / templates / Name des Templates / " und dann den app Ordner aufrufen. Hello, here is the path to the app folder of the template. The path described in the manual is misleading. "Folder where Joomla is installed / templates / name of the template /" and then go in the app folder.
Support Team posted this 01 November 2018
We will update the default Themler theme for Joomla on the website as soon as possible.
Hello, We will update the default Themler theme for Joomla on the website as soon as possible. Sincerely, Nettie
Giuma
Giuma posted this 01 November 2018
thanks so much for update desktop application
info1204
info1204 posted this 02 November 2018
Great support..thank you from Germany
SRuff
SRuff posted this 02 November 2018
Sorry for my ignorance, but where does one download this hot-fix and/or how to install it on website? Thank you
Support Team posted this 02 November 2018
To update a theme to the latest Themler version, please open it in Themler for editing, then click on "Updates (1)" at the top and update.
Hello, To update a theme to the latest Themler version, please open it in Themler for editing, then click on "Updates (1)" at the top and update. Sincerely, Nettie
SRuff
Hi, how do I do this on joomla? I can't edit the template, I just get an empty pop-up.
> Hello, > > To update a theme to the latest Themler version, please open it in Themler for editing, then click on "Updates (1)" at the top and update. > > Sincerely, > Nettie Hi, how do I do this on joomla? I can't edit the template, I just get an empty pop-up.
BePe
BePe posted this 02 November 2018
Well, this works but as soon as you download a theme themler is updating. At that moment it is puting the wrong settings back and you will have the same problem.
Pierre665
Pierre665 posted this 03 November 2018
Hello Team Themler,
Wow! Seriously? You had not planned a patch for your client before the update of Joomla 3.9?
Version 3.9 is planned for several months and beta versions were available for the developers to do tests
Now, I have to edit several .php files on the 20 websites I manage to make Themler work ??
You do not have a .zip patch to install directly via joomal?
Looking forward to your answer.
Pierre
Hello Team Themler, Wow! Seriously? You had not planned a patch for your client before the update of Joomla 3.9? Version 3.9 is planned for several months and beta versions were available for the developers to do tests Now, I have to edit several .php files on the 20 websites I manage to make Themler work ?? You do not have a .zip patch to install directly via joomal? Looking forward to your answer. Regards, Pierre
Vitaliy WD
Vitaliy WD posted this 05 November 2018
I am surprised that Themler developers not test beta releases of CMS on compatibility...
Next Joomla 4 Alpha 5 already not work with Themler as there is Error: Class 'JRequest' not found because JRequest Class is deprecated since Joomla 1.5: https://api.joomla.org/cms-3/classes/JRequest.html
This is Alpha, but I don't think that Joomla will bring back JRequest Class in Beta or Stable.
I am surprised that Themler developers not test beta releases of CMS on compatibility... Next Joomla 4 Alpha 5 already not work with Themler as there is `Error: Class 'JRequest' not found` because `JRequest` Class is deprecated since Joomla 1.5: https://api.joomla.org/cms-3/classes/JRequest.html This is Alpha, but I don't think that Joomla will bring back `JRequest` Class in Beta or Stable.
Seppe
Seppe posted this 05 November 2018
I guess you will have to wait for a long time :) :) :)
Hello Team Themler,
Pierre
I guess you will have to wait for a long time :) :) :) > Hello Team Themler, > > Wow! Seriously? You had not planned a patch for your client before the update of Joomla 3.9? > > Version 3.9 is planned for several months and beta versions were available for the developers to do tests > > Now, I have to edit several .php files on the 20 websites I manage to make Themler work ?? > > You do not have a .zip patch to install directly via joomal? > > Looking forward to your answer. > > Regards, > > Pierre >
DISALO.es
DISALO.es posted this 06 November 2018
after the update still have problems with the 404 page and Home page ????
riwen
riwen posted this 07 November 2018
It works correctly, thanks!
hotfaucet
hotfaucet posted this 07 November 2018
I have applied the changes as requested but I keep getting a completely blank screen and themler is unable to load. Please help.
Hello, I have applied the changes as requested but I keep getting a completely blank screen and themler is unable to load. Please help.
Seppe
Seppe posted this 08 November 2018
Good afternoon
always getting the error:
SERVER ERROR
Bad gateway
http://generator-de.themler.io/render
I can only push a button "retry", but it loops
Good afternoon always getting the error: > SERVER ERROR Bad gateway http://generator-de.themler.io/render I can only push a button "retry", but it loops
Support Team posted this 08 November 2018
We are sorry for the issue, our developers are working at fixing it ASAP.
Hello, We are sorry for the issue, our developers are working at fixing it ASAP. Sincerely, Nettie
