Themler HotFix Update v.472 Update (31-Oct-2018)
Support Team posted this 31 October 2018
Hi everyone,
This HotFix update includes the following fixes:
  • Joomla 3.9 compatibility.
    If you already updated Joomla to version 3.9 and encountered a problem with launching Themler please follow this instruction and then update Themler;
  • Fixed issue with shortcodes;
  • Fixed issue with 404 templates in Joomla themes in Themler Desktop.
Themler Team
Hi everyone, This HotFix update includes the following fixes: - Joomla 3.9 compatibility. If you already updated Joomla to version 3.9 and encountered a problem with launching Themler please follow [this instruction](page:173620) and then update Themler; - Fixed issue with shortcodes; - Fixed issue with 404 templates in Joomla themes in Themler Desktop. Sincerely, Themler Team
32 Comments
lesergei
lesergei posted this 08 November 2018
Good afternoon
always getting the error:
SERVER ERROR
Bad gateway
http://generator-de.themler.io/render
I can only push a button "retry", but it loops
I too have this problem, on the server that hosts my site and also on the desktop version.
Go go go ... Thanks
> Good afternoon > > always getting the error: > > > SERVER ERROR > Bad gateway > http://generator-de.themler.io/render > > I can only push a button "retry", but it loops Hi, I too have this problem, on the server that hosts my site and also on the desktop version. Go go go ... Thanks
gilles.schmitt
gilles.schmitt posted this 08 November 2018
Good afternoon
SERVER ERROR
Bad gateway
I too have this problem, on 2 servers
> > Good afternoon > > > > always getting the error: > > > > > SERVER ERROR > > Bad gateway > > http://generator-de.themler.io/render > > I too have this problem, on 2 servers
Support Team posted this 08 November 2018
The issue is fixed, please try now.
Hello, The issue is fixed, please try now. Sincerely, Nettie
info1640
info1640 posted this 08 November 2018
Hi everyone,
Themler Team
Hi I have tried to fix the problem following your instruction, but when themler tries to update, it kicks me out of joomla backend.
> Hi everyone, > > This HotFix update includes the following fixes: > > - Joomla 3.9 compatibility. > If you already updated Joomla to version 3.9 and encountered a problem with launching Themler please follow [this instruction](page:173620) and then update Themler; > - Fixed issue with shortcodes; > - Fixed issue with 404 templates in Joomla themes in Themler Desktop. > > Sincerely, > Themler Team Hi I have tried to fix the problem following your instruction, but when themler tries to update, it kicks me out of joomla backend.
info1640
Support Team posted this 09 November 2018
info1640,
Could you please create a new private topic and provide temporary access to your website for us to investigate the issue?
**info1640**, Could you please create a new private topic and provide temporary access to your website for us to investigate the issue? Sincerely, Nettie
luca.anchini
luca.anchini posted this 12 November 2018
I've a big problem with my website joomla 3.9 and Themler.
I've followed the instruction to fix the backend of themler and it works but the registration page doesn't work.
As you can see into the attached images:
1) With default template the registration page works perfectly (the website has also the last version of Community Builder)
2) With template I've created with Themler it appears totaly blank (even if before 3.9 joomla version, it worked normally)
How can I solve this?
I've this issue only into the registration page.
I've attached also the consolle page of google chrome where are some errors.
Hi, I've a big problem with my website joomla 3.9 and Themler. I've followed the instruction to fix the backend of themler and it works but the registration page doesn't work. As you can see into the attached images: 1) With default template the registration page works perfectly (the website has also the last version of Community Builder) 2) With template I've created with Themler it appears totaly blank (even if before 3.9 joomla version, it worked normally) How can I solve this? I've this issue only into the registration page. I've attached also the consolle page of google chrome where are some errors.
luca.anchini
Ok, the problem was not by the template (almost only by template) but (also) by a javascript banner.
> Hi, > I've a big problem with my website joomla 3.9 and Themler. > I've followed the instruction to fix the backend of themler and it works but the registration page doesn't work. > As you can see into the attached images: > 1) With default template the registration page works perfectly (the website has also the last version of Community Builder) > 2) With template I've created with Themler it appears totaly blank (even if before 3.9 joomla version, it worked normally) > > How can I solve this? > I've this issue only into the registration page. > > I've attached also the consolle page of google chrome where are some errors. > Ok, the problem was not by the template (almost only by template) but (also) by a javascript banner.
Zierikzeker
Zierikzeker posted this 22 November 2018
I've done the update and now I get the pop up all the time with retry. Help me, I need to create a website!
JEMmarketing
JEMmarketing posted this 28 November 2018
I have edited the files as indicated above for my Joomla 3.9.1 website, but when I try to "Edit Template" I am receiving the following error:
[PHP_ERROR]{"message":"\n\nOS: Linux gator3300.hostgator.com 4.14.72-113.ELK.el6.x86_64 #1 SMP Thu Sep 27 14:43:12 CDT 2018 x86_64\nPHP: 7.1.14\nerror handler: A non well formed numeric value encountered\nArray\n(\n [value] => 256M\n [str] => 256m\n)\n Callstack: \n -> Helper::toBytes('256M')\n -> Helper::getMemoryLimit()\n -> Helper::tryAllocateMemory()\n -> ExportController::execute(array(4) { ... })\n\n\n","type":"E_NOTICE","file":"/home1/mario69/public_html/templates/bbq_king_newhdr/app/classes/Helper.php","line":585}[PHP_ERROR]
I have an urgent request from my client to change the business address, which is in the template footer. The site also has an SSL certificate. Please let me know how to fix this.
I have edited the files as indicated above for my Joomla 3.9.1 website, but when I try to "Edit Template" I am receiving the following error: [PHP_ERROR]{"message":"\n\nOS: Linux gator3300.hostgator.com 4.14.72-113.ELK.el6.x86_64 #1 SMP Thu Sep 27 14:43:12 CDT 2018 x86_64\nPHP: 7.1.14\nerror handler: A non well formed numeric value encountered\nArray\n(\n [value] => 256M\n [str] => 256m\n)\n Callstack: \n -> Helper::toBytes('256M')\n -> Helper::getMemoryLimit()\n -> Helper::tryAllocateMemory()\n -> ExportController::execute(array(4) { ... })\n\n\n","type":"E_NOTICE","file":"\/home1\/mario69\/public_html\/templates\/bbq_king_newhdr\/app\/classes\/Helper.php","line":585}[PHP_ERROR] I have an urgent request from my client to change the business address, which is in the template footer. The site also has an SSL certificate. Please let me know how to fix this.
Support Team posted this 29 November 2018
Zierikzeker,
Please let us know if the issue is present after updating to the latest v.475 for you.
JEMmarketing,
Please create a new private topic and provide temporary access to your website in it.
**Zierikzeker**, Please let us know if the issue is present after updating to the latest v.475 for you. **JEMmarketing**, Please create a new private topic and provide temporary access to your website in it. Sincerely, Nettie
angelestuardo
angelestuardo posted this 06 December 2018
It works again, thanks!
