Submenu under magnify on prestashop
Kevin Doussaint
Kevin Doussaint posted this 07 November 2018
When I put my mouse over my submenu wich is positionned on a picture (with magnify option that I cannot disable on prestashop ...) so the submenu under the magnify option, also on mobiles !
You can check it here : https://bytatiefofie.fr/tissus/274-tissu-maille-viscose-lurex-clair.html
I tried to make a z index to 0 on submenu and to 5 on picture but did not worked.
Thanks for help !
Kevin
Hi, When I put my mouse over my submenu wich is positionned on a picture (with magnify option that I cannot disable on prestashop ...) so the submenu under the magnify option, also on mobiles ! You can check it here : https://bytatiefofie.fr/tissus/274-tissu-maille-viscose-lurex-clair.html I tried to make a z index to 0 on submenu and to 5 on picture but did not worked. Thanks for help ! Kevin
Support Team posted this 07 November 2018
Hello Kevin,
z-index for the product image is set to 100 right now while the submenu has z-index:0; at some levels and 100 at others (i.e. z-index of all levels of the menu (list item, dropdown, nav bar, etc.) matters here).
Try adding this code to Home -> Settings -> Additional CSS:
#wrap .mousetrap {
  z-index:99 !important;
Hello Kevin, z-index for the product image is set to 100 right now while the submenu has z-index:0; at some levels and 100 at others (i.e. z-index of all levels of the menu (list item, dropdown, nav bar, etc.) matters here). Try adding this code to Home -> Settings -> Additional CSS: #wrap .mousetrap { z-index:99 !important; } Gina Themler Support
Kevin Doussaint
Kevin Doussaint posted this 08 November 2018
Hello Kevin,
#wrap .mousetrap {
It works Fine thanks a lot Gina :)
> Hello Kevin, > > z-index for the product image is set to 100 right now while the submenu has z-index:0; at some levels and 100 at others (i.e. z-index of all levels of the menu (list item, dropdown, nav bar, etc.) matters here). > > Try adding this code to Home -> Settings -> Additional CSS: > > #wrap .mousetrap { > z-index:99 !important; > } > > Gina > Themler Support It works Fine thanks a lot Gina :)
