woocommerce templates
mike77
mike77 posted this 08 November 2018
Dear support engineer.
after adding store templates to my wordpress website Themler only adds the products template.
Where can I find the other templates?
regarding,
Mike van den Berg
Dear support engineer. after adding store templates to my wordpress website Themler only adds the products template. Where can I find the other templates? regarding, Mike van den Berg
Support Team posted this 09 November 2018
Hello Mike,
All template can be found in Themler in the dropdown list here:
Could you, please, specify where you are trying to add a template?
Hello Mike, All template can be found in Themler in the dropdown list here: !template-list.png! Could you, please, specify where you are trying to add a template? Gina Themler Support
mike77
mike77 posted this 09 November 2018
Hi Gina,
I only find the products page, no Product Details and Shopping cart
(see attachments)
Regards, Mike
Hi Gina, I only find the products page, no Product Details and Shopping cart (see attachments) Regards, Mike
Support Team posted this 12 November 2018
WooCommerce should be installed in Wordpress, so that all store templates ar available in Themler. This article should be helpful:
https://answers.themler.io/articles/4021/how-to-install-woocommerce
Hello, WooCommerce should be installed in Wordpress, so that all store templates ar available in Themler. This article should be helpful: https://answers.themler.io/articles/4021/how-to-install-woocommerce Sincerely, Nettie
mike77
mike77 posted this 12 November 2018
YES,
somehow the woocommerce plugin was disabled.
thanx!
YES, somehow the woocommerce plugin was disabled. thanx!
Mike, you are welcome! Please feel free to contact us in any other case.
Mike, you are welcome! Please feel free to contact us in any other case. Sincerely, Nettie
mike77
mike77 posted this 14 November 2018
I also had a question about conditional menu's.
Is this possible in Themler?
I normally use the plugin Conditional menus from Themify, but does not work in Themler?
Mike
Nettie, I also had a question about conditional menu's. Is this possible in Themler? I normally use the plugin Conditional menus from Themify, but does not work in Themler? regards, Mike
Support Team posted this 15 November 2018
Hello Mike,
There is not such special menu type in Themler, however you may try to use several menus and enable/disable them on specific pages or templates. If they are horizontal menus, you may try putting them into different sidebars, and then show/hide those sidebars for separate templates. For a vertical menu that is supposed to show in a widget area, you may try the same solution with sidebars, or use "Show widget on" option in Wordpress to display the menu on selected pages.
Hello Mike, There is not such special menu type in Themler, however you may try to use several menus and enable/disable them on specific pages or templates. If they are horizontal menus, you may try putting them into different sidebars, and then show/hide those sidebars for separate templates. For a vertical menu that is supposed to show in a widget area, you may try the same solution with sidebars, or use "Show widget on" option in Wordpress to display the menu on selected pages. Sincerely, Nettie
