Error code when clicking edit template after upgrading to newest version of Joomla
robert157
robert157 posted this 09 November 2018
Warning: require_once(/home1/krundo/public_html/trystband.com/administrator/includes/toolbar.php): failed to open stream: No such file or directory in /home1/krundo/public_html/trystband.com/templates/untitled/app/index.php on line 25
Fatal error: require_once(): Failed opening required '/home1/krundo/public_html/trystband.com/administrator/includes/toolbar.php' (include_path='.:/opt/php56/lib/php') in /home1/krundo/public_html/trystband.com/templates/untitled/app/index.php on line 25
Warning: require_once(/home1/krundo/public_html/trystband.com/administrator/includes/toolbar.php): failed to open stream: No such file or directory in /home1/krundo/public_html/trystband.com/templates/untitled/app/index.php on line 25 Fatal error: require_once(): Failed opening required '/home1/krundo/public_html/trystband.com/administrator/includes/toolbar.php' (include_path='.:/opt/php56/lib/php') in /home1/krundo/public_html/trystband.com/templates/untitled/app/index.php on line 25
Support Team posted this 09 November 2018
This is related to Joomla 3.9 update. Please follow these steps:
https://answers.themler.io/articles/173620/how-to-fix-the-error-after-updating-to-joomla-3-9
And after this update Themler to the latest version.
Hello, This is related to Joomla 3.9 update. Please follow these steps: https://answers.themler.io/articles/173620/how-to-fix-the-error-after-updating-to-joomla-3-9 And after this update Themler to the latest version. Sincerely, Nettie
michal.k.stepan
michal.k.stepan posted this 23 November 2018
Support Team posted this 23 November 2018
You are welcome!
You are welcome! Sincerely, Nettie
zmeskal
zmeskal posted this 03 January 2019
To fix a bug with editing a template after updating on joomla 3.9 I used the above procedure. Everything went wrong, in one case, the following error occurred after pressing the "Edit template" button:
[PHP_ERROR]{"message":"\n\nOS: Linux wl26-f185 2.6.32-696.18.7.el6.x86_64 #1 SMP Thu Jan 4 17:31:22 UTC 2018 x86_64\nPHP: 7.1.5\nerror handler: A non well formed numeric value encountered\nArray\n(\n [value] => 128M\n [str] => 128m\n)\n Callstack: \n -> Helper::toBytes('128M')\n -> Helper::getMemoryLimit()\n -> Helper::tryAllocateMemory()\n -> ExportController::execute(array(4) { ... })\n\n\n","type":"E_NOTICE","file":"/data/web/virtuals/37340/virtual/www/templates/zp/app/classes/Helper.php","line":585}[PHP_ERROR]
This is the error on the site :
Warning: Parameter 2 to modChrome_block() expected to be a reference, value given in /data/web/virtuals/37340/virtual/www/templates/zp/html/modules.php on line 57
Warning: Parameter 3 to modChrome_block() expected to be a reference, value given in /data/web/virtuals/37340/virtual/www/templates/zp/html/modules.php on line 57
Can you help me ?
To fix a bug with editing a template after updating on joomla 3.9 I used the above procedure. Everything went wrong, in one case, the following error occurred after pressing the "Edit template" button: [PHP_ERROR]{"message":"\n\nOS: Linux wl26-f185 2.6.32-696.18.7.el6.x86_64 #1 SMP Thu Jan 4 17:31:22 UTC 2018 x86_64\nPHP: 7.1.5\nerror handler: A non well formed numeric value encountered\nArray\n(\n [value] => 128M\n [str] => 128m\n)\n Callstack: \n -> Helper::toBytes('128M')\n -> Helper::getMemoryLimit()\n -> Helper::tryAllocateMemory()\n -> ExportController::execute(array(4) { ... })\n\n\n","type":"E_NOTICE","file":"\/data\/web\/virtuals\/37340\/virtual\/www\/templates\/zp\/app\/classes\/Helper.php","line":585}[PHP_ERROR] This is the error on the site : Warning: Parameter 2 to modChrome_block() expected to be a reference, value given in /data/web/virtuals/37340/virtual/www/templates/zp/html/modules.php on line 57 Warning: Parameter 3 to modChrome_block() expected to be a reference, value given in /data/web/virtuals/37340/virtual/www/templates/zp/html/modules.php on line 57 Can you help me ? Thanks
