problems with the position of the mainmenu
arawolf
arawolf posted this 13 November 2018
sometimes when i scroll to the bottom the central mainmenu, who must positioned on the top of the page, and fill the w
hole screen, goes to the left site. See attachment. How can i solved this problem. Domain http://test-ararin.be/test3
sometimes when i scroll to the bottom the central mainmenu, who must positioned on the top of the page, and fill the w!Knipsel.JPG!hole screen, goes to the left site. See attachment. How can i solved this problem. Domain http://test-ararin.be/test3
arawolf
arawolf posted this 20 November 2018
What's the problem with the support. No reaction at all ... pitty
Support Team posted this 19 December 2018
Hello Kris,
I apologize for the delay in reply.
I can see that you have already changed the theme, but if you are going to use the old theme in future, please, attach it here, so I could test the issue.
My assumption is that some extension may be causing this, but I need the theme to check.
Hello Kris, I apologize for the delay in reply. I can see that you have already changed the theme, but if you are going to use the old theme in future, please, attach it here, so I could test the issue. My assumption is that some extension may be causing this, but I need the theme to check. Thank you Gina Themler Support
