Image name problem
1157-619
1157-619 posted this 19 November 2018
Image name code problem HTML
When I create an image and the image name of my file e.g. "anaconda.jpg" and then export the template, then Themler exported in the code for the image "2ac48f1d02f01803c01b9330cc9979_anaconda.jpg".
This is very bad for search engines.
How can you fix the error?
Thanks for answers
Image name code problem HTML When I create an image and the image name of my file e.g. "anaconda.jpg" and then export the template, then Themler exported in the code for the image "2ac48f1d02f01803c01b9330cc9979_anaconda.jpg". This is very bad for search engines. How can you fix the error? Thanks for answers
1157-619
1157-619 posted this 26 November 2018
Do not have a solution to the problem?
1157-619
1157-619 posted this 06 December 2018
Hello support team, do you have an answer and a solution for that?
admin34
admin34 posted this 08 December 2018
I have ranked lots of sites I made in themler in first position in google. My understanding is that the alt is the most important and you can add that in themler be clicking on the image in themler
Giuma
Giuma posted this 09 December 2018
the most important factor are Also the good use of h1 h2 and h3, and tag title of pages, all in quality and original contents
Support Team posted this 20 December 2018
Sorry for the delay in reply.
Unfortunately, you can't affect how image file names are changed during export in Themler.
But as Allan mentioned above, SEO is looking up for image alt text, make sure you specify that for every image in Themler.
Hello, Sorry for the delay in reply. Unfortunately, you can't affect how image file names are changed during export in Themler. But as Allan mentioned above, SEO is looking up for image alt text, make sure you specify that for every image in Themler. Gina Themler Support
