To erase the slide occur error
polt_01
polt_01 posted this 22 November 2018
Dear Support,
I tried to erase a slide but when I click on "remove" this error happens, please see attached.
www.dentalrio.com.mx
Dear Support, I tried to erase a slide but when I click on "remove" this error happens, please see attached. www.dentalrio.com.mx Thanks
Support Team posted this 23 November 2018
If you are using vpn, proxy, etc, try disabling it and make changes again.
Can you also try updating the theme to Themler latets version?
If it still doesn't work, let us know. We will move this case to Private and investigate this issue further.
Hello, If you are using vpn, proxy, etc, try disabling it and make changes again. Can you also try updating the theme to Themler latets version? If it still doesn't work, let us know. We will move this case to Private and investigate this issue further. Gina Themler Support
