Server Error
FAGE
FAGE posted this 26 November 2018
Hi, I am trying to edit the theme but it gives the error in the attachment. How can I solve?
Support Team posted this 26 November 2018
If you are using Joomla 3.9, try the hotfix below (after updating the template with latest Themler version, the issue should not repeat):
  • Open theme folder on the server: www/Joomla_directory/templates;
  • open /app folder;
  • open index.php for editing in any html or text editor;
  • find the line
    require_once JPATH_BASE . DS . 'includes' . DS . 'toolbar.php';
and replace it with the following line:
$prefix = version_compare(JVERSION, '3.9', '>=') ? 'sub' : '';
require_once JPATH_BASE . DS . 'includes' . DS . $prefix . 'toolbar.php';;
  • open /app/start folder;
  • open data.php file for editing and follow step 4;
  • open manifest.php file for editing and follow step 4;
  • start Themler.
Hello, If you are using Joomla 3.9, try the hotfix below (after updating the template with latest Themler version, the issue should not repeat): - Open theme folder on the server: www/Joomla_directory/templates; - open /app folder; - open index.php for editing in any html or text editor; - find the line require_once JPATH_BASE . DS . 'includes' . DS . 'toolbar.php'; and replace it with the following line: $prefix = version_compare(JVERSION, '3.9', '>=') ? 'sub' : ''; require_once JPATH_BASE . DS . 'includes' . DS . $prefix . 'toolbar.php';; - open /app/start folder; - open data.php file for editing and follow step 4; - open manifest.php file for editing and follow step 4; - start Themler. Gina Themler Support
FAGE
thanks worked
thanks worked
etchenet
etchenet posted this 04 December 2018
thanks worked
thanks worked
me321
me321 posted this 24 January 2019
Dear Themler,
Is this fix only for Joomla? Can I apply it for the desktop version, using Drupal? This thing keeps haunting me...
Thanks!
Dear Themler, Is this fix only for Joomla? Can I apply it for the desktop version, using Drupal? This thing keeps haunting me... Thanks!
Support Team posted this 24 January 2019
The fix above is for Joomla 3.9 on a hosted server or localhost. Do you have server error with Themler on Drupal? Please use the following solution:
1.Close Themler application.
2.Find the folder:
C:\Users[username]\AppData\Local\Themler
3.Rename it and restart Themler Desktop.
  1. Start Themler for Drupal. Let us know if the issue is still present.
Hello, The fix above is for Joomla 3.9 on a hosted server or localhost. Do you have server error with Themler on Drupal? Please use the following solution: 1.Close Themler application. 2.Find the folder: C:\Users[username]\AppData\Local\Themler 3.Rename it and restart Themler Desktop. 4. Start Themler for Drupal. Let us know if the issue is still present. Sincerely, Nettie
me321
Hi Nettie,
Thanks for the reply. I opened a new ticket, as it is not related to Joomla. I tried this solution and it doesn't work.
Hi Nettie, Thanks for the reply. I opened a new ticket, as it is not related to Joomla. I tried this solution and it doesn't work.
We have answered in that topic.
Hello, We have answered in that topic. Sincerely, Nettie
