PrestaShop 1.7.4.4 and Themler 475 - Cannot install Template
matrix630307
matrix630307 posted this 29 November 2018
When i use the standard-Template by open Themler and update this on 475, it will not work by install on PrestaShop 1.7.4.4. I have the message, that the Template is not compatible with PrestaShop 1.7.
What can i do?
When i use the standard-Template by open Themler and update this on 475, it will not work by install on PrestaShop 1.7.4.4. I have the message, that the Template is not compatible with PrestaShop 1.7. What can i do?
matrix630307
OK - i have found all - but your description of your website is not actual. Many things are other than you descripts.
stryjek-www
stryjek-www posted this 29 November 2018
Czy themler będzie dalej aktualizował PRESTASHOP 1.7? Czy themelr już nie działa z aktualizacjami?
Support Team posted this 29 November 2018
Please make sure to download and install namely default Themler theme for Prestashop 1.7, not Themler theme for Prestashop. Please follow this article to install and use it:
https://answers.themler.io/articles/151814/how-to-install-prestashop-1-7-theme-beta-version
Hello, Please make sure to download and install namely default Themler theme for Prestashop 1.7, not Themler theme for Prestashop. Please follow this article to install and use it: https://answers.themler.io/articles/151814/how-to-install-prestashop-1-7-theme-beta-version Sincerely, Nettie
matrix630307
Hi Nettie
Exact - i have made this before your answer. It will work for the first step's. I will try this in next days...
Thank you and a good evening from switzerland... here is now 9.20 p.m... :)
Hi Nettie Exact - i have made this before your answer. It will work for the first step's. I will try this in next days... Thank you and a good evening from switzerland... here is now 9.20 p.m... :)
matrix630307
ok - and this i understand:
is not in my language-"room".... :)
ok - and this i understand: Czy themler będzie dalej aktualizował PRESTASHOP 1.7? Czy themelr już nie działa z aktualizacjami? is not in my language-"room".... :)
