error 500 after updat php to 7.2.12
Dreeshoek
Dreeshoek posted this 03 December 2018
the sit no longer works after updating php 7.2.12. the edit the template is no longer clickable
6 Comments
Support Team posted this 03 December 2018
Could you please try applying this fix?
http://answers.themler.io/articles/173620/how-to-fix-the-error-after-updating-to-joomla-3-9
When editor opens, please, update your theme to the latest version. Latest Themler release has this issue fixed.
Hello, Could you please try applying this fix? http://answers.themler.io/articles/173620/how-to-fix-the-error-after-updating-to-joomla-3-9 When editor opens, please, update your theme to the latest version. Latest Themler release has this issue fixed. Gina Themler Support
Dreeshoek
the "edit Template" button does not work yet. However, the hand appears.
Clicks does not work yet
the "edit Template" button does not work yet. However, the hand appears. Clicks does not work yet
Dreeshoek
Fatal error: Cannot use empty list in /home/sites/site44102/web/templates/linques/library/Designer/Shortcodes.php on line 1910
Dreeshoek
there is something wrong with the template with the new version of php
Dreeshoek
Dreeshoek posted this 04 December 2018
It worked. The site is installed via localhost on local PC. The template updated, then made an export. this export is imported into the new site
Support Team posted this 04 December 2018
Thank you for letting us know the result.
If you encounter same issue again (I mean the last error message), try disabling Shordcodes plugin to open Themler Editor, then update the theme to the latest version.
Thank you for letting us know the result. If you encounter same issue again (I mean the last error message), try disabling Shordcodes plugin to open Themler Editor, then update the theme to the latest version. Gina Themler Support
