Copy theme to new one, change the layout but thumbnail of theme remains the same
Janno Hordijk
Janno Hordijk posted this 14 December 2018
How can I force Themler to recreate the thumbnail of the theme that is shown in WordPress Themes?
Support Team posted this 5 weeks ago
Hello Janno,
I apologize for the delay.
I couldn't reproduce the issue if I use File -> Save as Copy option in Themler. Once I edit the copied theme and publish it, I can see it in wp-admin -> Appearance -> Themes with new thumbnail.
Could you please describe how you make the copies?
Hello Janno, I apologize for the delay. I couldn't reproduce the issue if I use File -> Save as Copy option in Themler. Once I edit the copied theme and publish it, I can see it in wp-admin -> Appearance -> Themes with new thumbnail. Could you please describe how you make the copies? Gina Themler Support
Janno Hordijk
Janno Hordijk posted this 5 weeks ago
Hi Gina, no problem, I only did a Save as but forgot to publish it. It works as you described. Thank you!
Best regards, Janno
Hi Gina, no problem, I only did a Save as but forgot to publish it. It works as you described. Thank you! Best regards, Janno
