Qustionsa bout Themeler
benns
benns posted this 15 December 2018
  1. Do you have shape dividers?
  2. Can I overlap columns and images for overlaying effects?
  3. Do you have elements like: Price Table, Space, Call to Action, Lists, Image Sliders, Login In, ...etc? Can you send me a list?
  4. Can I use short=code membership plugins like Ultimate Member with no issues or plugins in general? I use elementor pg builder and has issues with plugins?
  5. Is the purchase price one-time fee or is that annually?
  6. Do you have a lot of text shadow and transparency options (Buttons, Headers, Backgronds)?
  7. What are your imae background options? (ie" Overlay, Transparency, Fix. Scoll, Width...etc?
  8. Do I need know any coding or work with code?
  9. Can I make changes via themler designer or does it have to be via wordpress editor dealing with code?
  10. Can I save my theme/designs on to pc as backup?
So for the questions but I want to find excellent product that does great wordpress designs and options without working with code or frustrations with elements...etc. Thanks so much.
1. Do you have shape dividers? 2. Can I overlap columns and images for overlaying effects? 3. Do you have elements like: Price Table, Space, Call to Action, Lists, Image Sliders, Login In, ...etc? Can you send me a list? 5. Can I use short=code membership plugins like Ultimate Member with no issues or plugins in general? I use elementor pg builder and has issues with plugins? 6. Is the purchase price one-time fee or is that annually? 7. Do you have a lot of text shadow and transparency options (Buttons, Headers, Backgronds)? 8. What are your imae background options? (ie" Overlay, Transparency, Fix. Scoll, Width...etc? 9. Do I need know any coding or work with code? 10. Can I make changes via themler designer or does it have to be via wordpress editor dealing with code? 11. Can I save my theme/designs on to pc as backup? So for the questions but I want to find excellent product that does great wordpress designs and options without working with code or frustrations with elements...etc. Thanks so much.
9 Comments
Support Team posted this 17 December 2018
  1. Do you have shape dividers? Do you
Do you mean separators for different layout elements? Yes so, then yes, there are different kinds of separators
2.Can I overlap columns and images for overlaying effects?
Yes, you can. You can also find some pre-made layouts like this in out library, for example:
3.Do you have elements like: Price Table, Space, Call to Action, Lists, Image Sliders, Login In, ...etc? Can you send me a list?
There are different kinds of controls including call to action, lists, image sliders, login, etc. Style elements like lists and sliders can be created and supported in Themler, but such functional elements like Login, call to action buttons, prices are only styled in themler. There are some php forms that you can create in Themler but this would require a bit of coding as explained jere https://answers.themler.io/articles/71585/form
Usually, prices, logins, submit forms are used for the temlates that are created for particular CMS (liek Wordpress, Joomla, etc.). In this case Themler would provide design and selected CMS would provide the functionality.
4.Can I use shortcode membership plugins like Ultimate Member with no issues or plugins in general? I use elementor pg builder and has issues with plugins?
We cannot guanrantee full compatability with all 3rd party plugins. Most of them work fine with Themler but every particular one needs to be tested by the user.
5.Is the purchase price one-time fee or is that annually?
Once you purchase a license, you get it for the lifetime along with one year subscription. This means you can download and use new released during one year. When the year is ove, you can extend your subscription for another year to get new releases or just stick to the last version you had and continue using without paying for another year.
6.Do you have a lot of text shadow and transparency options (Buttons, Headers, Backgronds)?
Yes, there are a lot of options to style such elements as buttons, headers, backgrounds, etc., including animation effects.
7.What are your imae background options? (ie" Overlay, Transparency, Fix. Scoll, Width...etc?)
You can apply different style techniques to a background images, including transparency, opacity, postion, size and filters:
8.Do I need know any coding or work with code?
In general - no, you don't need to know any coding. Sometimes users need to implement 3rd party code snippets or change the style of some plugin used on the site that Themler doesn't control - in this case some custom coding may be required. You can contact support for the help. Almost all custom code can be added directly in Themler.
9.Can I make changes via themler designer or does it have to be via wordpress editor dealing with code?
You can edit directly in Themler.
10.Can I save my theme/designs on to pc as backup?
Yes, you can.
Let us know if some answers are not clear.
Hello, > 1. Do you have shape dividers? Do you Do you mean separators for different layout elements? Yes so, then yes, there are different kinds of separators > 2.Can I overlap columns and images for overlaying effects? Yes, you can. You can also find some pre-made layouts like this in out library, for example: !overlap.png! >3.Do you have elements like: Price Table, Space, Call to Action, Lists, Image Sliders, Login In, ...etc? Can you send me a list? There are different kinds of controls including call to action, lists, image sliders, login, etc. Style elements like lists and sliders can be created and supported in Themler, but such functional elements like Login, call to action buttons, prices are only styled in themler. There are some php forms that you can create in Themler but this would require a bit of coding as explained jere https://answers.themler.io/articles/71585/form Usually, prices, logins, submit forms are used for the temlates that are created for particular CMS (liek Wordpress, Joomla, etc.). In this case Themler would provide design and selected CMS would provide the functionality. >4.Can I use shortcode membership plugins like Ultimate Member with no issues or plugins in general? I use elementor pg builder and has issues with plugins? We cannot guanrantee full compatability with all 3rd party plugins. Most of them work fine with Themler but every particular one needs to be tested by the user. >5.Is the purchase price one-time fee or is that annually? Once you purchase a license, you get it for the lifetime along with one year subscription. This means you can download and use new released during one year. When the year is ove, you can extend your subscription for another year to get new releases or just stick to the last version you had and continue using without paying for another year. >6.Do you have a lot of text shadow and transparency options (Buttons, Headers, Backgronds)? Yes, there are a lot of options to style such elements as buttons, headers, backgrounds, etc., including animation effects. >7.What are your imae background options? (ie" Overlay, Transparency, Fix. Scoll, Width...etc?) You can apply different style techniques to a background images, including transparency, opacity, postion, size and filters: !bgoptions.png! >8.Do I need know any coding or work with code? In general - no, you don't need to know any coding. Sometimes users need to implement 3rd party code snippets or change the style of some plugin used on the site that Themler doesn't control - in this case some custom coding may be required. You can contact support for the help. Almost all custom code can be added directly in Themler. >9.Can I make changes via themler designer or does it have to be via wordpress editor dealing with code? You can edit directly in Themler. >10.Can I save my theme/designs on to pc as backup? Yes, you can. Let us know if some answers are not clear. Gina Themler Support
benns
benns posted this 17 December 2018
I have another questions that I am confused about.....
(1) Why do you need to use/apply the CMS Button? What does that do?
(2) Can you not modify your site via themler after you apply the CMS button? Why do you have to go to the wordpress editor to make text changes? This is based on the video I was watching?
Thank You
Hi, I have another questions that I am confused about..... (1) Why do you need to use/apply the CMS Button? What does that do? (2) Can you not modify your site via themler after you apply the CMS button? Why do you have to go to the wordpress editor to make text changes? This is based on the video I was watching? Thank You
  1. Apply to CMS makes the changes in Themler reflect in CMS admin. For example, if you added some Joomla Module Position control, this position will be available in Joomla only after "Apply to CMS" button is clicked.
  2. You should be able to modify the theme in Themler also after pressing this button. If we speak about editing content, these are just different ways of editing content. You may continue editing theme and content in Themler, the video just shows how you or your customer can modify this content from CMS admin panel.
Hello, 1. Apply to CMS makes the changes in Themler reflect in CMS admin. For example, if you added some Joomla Module Position control, this position will be available in Joomla only after "Apply to CMS" button is clicked. 2. You should be able to modify the theme in Themler also after pressing this button. If we speak about editing content, these are just different ways of editing content. You may continue editing theme and content in Themler, the video just shows how you or your customer can modify this content from CMS admin panel. Sincerely, Nettie
benns
Perfect...I understand now...thanks
benns
benns posted this 18 December 2018
What is difference between a "Section" and a "Container"?
benns
I saw NICEPAGE what is the difference between that and themeler? Can NICEPAGE do all things I mention above?
Support Team posted this 18 December 2018
Section is a greater part of the layout, it takes full width of the sheett and can contain all other elements inside of it. See section tutorial here https://answers.themler.io/articles/19451/section-tutotials
Container is a simple element that can be of any set size and should be placed inside of a section, see tutorial here https://answers.themler.io/articles/4419/layout-container
Many Themler users were requesting the simpler design tool and the content editor. We have implemented those requests. Nicepage is fast, intelligent and easy-to-use. It allows creating modern designs based on any source in minutes. You can use an existing website, social network account or even a folder with images to create a modern and unique page just in seconds.
I would not tell for sure, but as far as I know it can do most of the things you mentioned. Please, contact Nicepage support directly to clarify each question.
>What is difference between a "Section" and a "Container"? Section is a greater part of the layout, it takes full width of the sheett and can contain all other elements inside of it. See section tutorial here https://answers.themler.io/articles/19451/section-tutotials Container is a simple element that can be of any set size and should be placed inside of a section, see tutorial here https://answers.themler.io/articles/4419/layout-container >I saw NICEPAGE what is the difference between that and themeler? Many Themler users were requesting the simpler design tool and the content editor. We have implemented those requests. Nicepage is fast, intelligent and easy-to-use. It allows creating modern designs based on any source in minutes. You can use an existing website, social network account or even a folder with images to create a modern and unique page just in seconds. >Can NICEPAGE do all things I mention above? I would not tell for sure, but as far as I know it can do most of the things you mentioned. Please, contact Nicepage support directly to clarify each question. Gina Themler Support
benns
Thanks for you reply. See I think Themler has amazing features (customization options and elements..etc), but I think it is too complex as wp theme designer. I find it is slow and the footer, header, body layout to complex. I think the nicepage is getting it right but it just needs more customization options and element (ie: Nav Menu Options, Price Table, Shape Dividers) have. Thanks so much.
Support Team posted this 5 weeks ago
Thank you for your feedback.
Nicepage is indeed a simpler tool.
It is being developed further so it may have more options in future.
Feel free to try it out.
Thank you for your feedback. Nicepage is indeed a simpler tool. It is being developed further so it may have more options in future. Feel free to try it out. Gina Themler Support
