No article on home (joomla, themler)
admin166
admin166 posted this 16 December 2018
With my Joomla template I don't want to have an article on the home. I can't hide this article in Themler. If I don't add a article in Joomla for home, home doesn't work at all.
Is there a way not to show an article on Home?
Best regards
Hello With my Joomla template I don't want to have an article on the home. I can't hide this article in Themler. If I don't add a article in Joomla for home, home doesn't work at all. Is there a way not to show an article on Home? Best regards
Support Team posted this 17 December 2018
If you go to Themler -> Home template -> Design (in the menu bar), you can disable CMS Content there:
This would only show content added via Themler on this particular template.
Hello, If you go to Themler -> Home template -> Design (in the menu bar), you can disable CMS Content there: !cms-content.png! This would only show content added via Themler on this particular template. Gina Themler Support
