Duplicate template
Lenglemetz
Lenglemetz posted this 4 weeks ago
Can you tell me what is the purpose of the duplication template option?
When I make a copy of the template because modifies my original template!
If I want it to be customizable (set default, reset default), I have to do something that breaks my website
Can you please integrate the fact that the template is DETACHED at its creation?
For information :
I only want to make a template with post image and without post image
POST import / export does not work with duplication
Hi, Can you tell me what is the purpose of the duplication template option? When I make a copy of the template because modifies my original template! If I want it to be customizable (set default, reset default), I have to do something that breaks my website Can you please integrate the fact that the template is DETACHED at its creation? For information : I only want to make a template with post image and without post image POST import / export does not work with duplication Regards,
Could you please try to enable the option "Customize template style" on the Posts tab for any of the templates and make the changes after this?
Hello, Could you please try to enable the option "Customize template style" on the Posts tab for any of the templates and make the changes after this? Sincerely, Nettie
Lenglemetz
Hello Nettie,
Ok, to have this option I have the choice between:
Set as default> so destroy my default template
Reset to default> destroyed the duplicate template
What do you think you prefer? ;-)
Hello Nettie, Ok, to have this option I have the choice between: Set as default> so destroy my default template Reset to default> destroyed the duplicate template What do you think you prefer? ;-) Regards,
As I assume, at the moment Posts controls of both templates are identical, so you may choose to set Set as default for any of them. Once you click then Customize template style, only the selected template will be changed, so Posts control designs on them are separated.
Hello, As I assume, at the moment Posts controls of both templates are identical, so you may choose to set Set as default for any of them. Once you click then Customize template style, only the selected template will be changed, so Posts control designs on them are separated. Sincerely, Nettie
Lenglemetz
but I do not have this option, to access this option I have to click on the two choices previously mentioned...
Hi, but I do not have this option, to access this option I have to click on the two choices previously mentioned... Regards
As mentioned before, "Set as default" for either of templates would be enough, as they should be identical so far. You may create a backup copy just in case before making such changes.
Hello, As mentioned before, "Set as default" for either of templates would be enough, as they should be identical so far. You may create a backup copy just in case before making such changes. Sincerely, Nettie
Lenglemetz
Have you tried before giving me this answer?
It does not work !
Hi, Have you tried before giving me this answer? It does not work ! Regards,
Let's check we see it in the same way:
1. You have duplicated the Post template.
2. You would like to remove Post Image for one of two Post templates and leave it for another one, right?
What exactly doesn't work?
Hello, Let's check we see it in the same way: 1. You have duplicated the Post template. 2. You would like to remove Post Image for one of two Post templates and leave it for another one, right? What exactly doesn't work? Sincerely, Nettie
