Sticky row and load javascript deffered
ZCompany
ZCompany posted this 3 weeks ago
Hi!
I use a cache plugin with option for loading of js deffered. When I turn it on - my sticky row in the header is no sticky anymore.
Can I change something in the header, so that I can use both the deffered option and the sticky row?
Here's the site: изработка на сайт
Thanks!
Hi! I use a cache plugin with option for loading of js deffered. When I turn it on - my sticky row in the header is no sticky anymore. Can I change something in the header, so that I can use both the deffered option and the sticky row? Here's the site: [изработка на сайт][1] [1]: https://mysuper.site Thanks!
8 Comments
ZCompany
Thanks, but I actually need to know what file to remove from deferred js loading. I've tried with bootstrap.js, and all other js files the theme is using - without result. I also excluded jquerry, but again - my row is not sticky, if I turn on deferred loading of js.
ZCompany
ZCompany posted this 2 weeks ago
Hi, Themler team! Can I get some help, please?
Hello Petia,
Sorry for the delay in reply.
Curently your site has white row in header sticky.
Have you disabled that plugin or do you need to keep the blue row sticky as well?
If that plugin is disabled, please, enable it.
Hello Petia, Sorry for the delay in reply. Curently your site has white row in header sticky. Have you disabled that plugin or do you need to keep the blue row sticky as well? If that plugin is disabled, please, enable it. Gina Themler Support
ZCompany
I need just the white row to be sticky.
And yes, the plugin was disabled. I have now enabled it.
I need just the white row to be sticky. And yes, the plugin was disabled. I have now enabled it.
The plugin is blocking jQuery that is responsible for making the menu stay fix exactly on scroll.
I can provide CSS code that makes the header sticky but it will be always sticky and fixed (regardless on scroll or not) and without that jQuery working you will see 50px gap on top when scrolling:
#section9 {
    position: fixed;
    top: 0;
    width: 100%;
    background-color: white;
    z-index: 99999;
    margin-top: 50px;
I can only suggest making entire header (along with the blue line sticky) to avoid that gap, or moving the top line above so there is no gap.
The plugin is blocking jQuery that is responsible for making the menu stay fix exactly on scroll. I can provide CSS code that makes the header sticky but it will be always sticky and fixed (regardless on scroll or not) and without that jQuery working you will see 50px gap on top when scrolling: #section9 { position: fixed; top: 0; width: 100%; background-color: white; z-index: 99999; margin-top: 50px; } I can only suggest making entire header (along with the blue line sticky) to avoid that gap, or moving the top line above so there is no gap. Gina Themler Support
ZCompany
Thank you!
If I make the entire header sticky, should I use again some code, like the one above? But maybe instead of #section9 I should use #header ?
Thank you! If I make the entire header sticky, should I use again some code, like the one above? But maybe instead of #section9 I should use #header ?
The code for entire header would be this:
header {
    position: fixed;
    top: 0;
    width: 100%;
    z-index: 99999;
The code for entire header would be this: header { position: fixed; top: 0; width: 100%; background-color: white; z-index: 99999; } Gina Themler Support
ZCompany
Thanks! All works now!
